![]() Everyone there is a "professional" machinist. Us tinkerers like to play with the machines. :-) Even build for $50 dollars what could be bought for $5. :-) ...lew... |
Then again some of us like the challenge.... I'm of the opinion you can not have enough quick change tool holders.
fab shop in '08; took a few years to enjoy being in the shop as a hobby. You do things, and think differently when you need to get paid for your time versus the enjoyment of the time. Quote:
having it to one side you will risk having a cant on your tool.
a much bigger difference than you might think.
Some day, when I quit "working", I'm sure I'll be more inclined to make some of my own tooling but I'll bet that 45 plus years of "buy rather than build" will be a hard habit to break. In any case, I have no doubt that I'll be able to keep as "busy" as I want to till the day I die... ![]()
Lew, I could give you a couple of PM quality responses, but I try not to stoop that low. As to the building a QCTP, why bother, when you can by new blocks from CDCO for $9-$25/ea, depending on size. I use the wedge type AXA (100 series) QCTP, used on the Phase II (sold through the swapsheet), the Aloris (sold to LW) and now on the Dorian, they all fit and work perfectly, for $9/ea. At times it pays to make tooling, other times it doesn't. I can have more blocks here in about 2-3 days, as many as I want, all the same, they are so cheap, I don't remove the tool, I leave it set up for the next time, just grab another block, load that, then keep that in hot standby. I've known about 50 people who just HAD to make their own QCTP, all of them saw their folly, eventfully and now use a bought QCTP system. http://cdcotools.com/ below the 50 or so loaded and ready.
jack Last edited by platypus20; 03-22-2014 at 01:55 PM. Reason: short stubby platypus fingers |
If I wanted too get more machine time in, the route I would take is make a tool-post that will accept off the shelf tool holders.
Oh MY! When I made mine, Aloris was still in the $$$ range per tool holder. $200-$300 type price. Even with five hours into a tool holder, it was cheaper to make than buy.
The knock offs on Enco are in $80 to $120 range. Hmm, but I've gotten faster at making them. CDCO.... $17! ![]() ![]() When you can buy a post and set of tools for $100... damn, just buy them and get back to turning metal. ![]() Meanwhile for my CNC Router.... it was much better to build ($5K) than versus a commercial machine ($15K). 4' x 4' bed with 8" Z height. I suck at wood carving, so this is kinda of cool. |
Don't get me wrong, I think what Lew did is exceptional, I couldn't justify the time involved and along with the current pricing, I got too much else to do.
jack |
Some of the import QCTPs are looking more appealing. Thanks for the links!
So I finally got some dimensions for my cross-slide and immediately trashed my initial design. It just plain would not fit. Here's round 2. Things changed: The T-slot is now in the tool post block rather than the holder. Holders are now simpler! There is now a short (20mm) socket-head cap screw between the tool holder and the T-slot nut. It being shorter will reduce flexing compared to a longer screw. The tool holder has 8mm thick flanges for securing tools. Bad things I'm seeing now: The tool sits quite a bit below the T-slot nut Vertical travel is very short Larger tooling will exacerbate the above problems Changes I'm investigating: making everything smaller: 8mm rod instead of 10mm. M8 securing screw instead of M10. 10mm T-slot nut instead of 12mm. |
