Old 03-31-2014, 08:21 PM
platypus20's Avatar
Boiler God
Default Gas Spud Orifices
I have a job in Vermont that needs the gas spud configuration changed to try to control a combustion rumble. The existing spuds now are a straight piece of 3/8" pipe, I'm going to have to enlarge the hole that the spud passes through the air diffuser, then screw a forged 3/8" cap on the spuds, that have holes drilled into the side. When orientated in the correct position, the gas will be injected into the air flow to change the mixture and the combustion, hopefully changing the harmonic that causes the combustion rumble. Between the 2 boilers I had to modify 50 caps
When the caps arrived, it was instantly apparent that either the company ordered them wrong or the supplier didn't heed our instructions. Forged caps can come in two different configurations, with a very thick top or a thin top. We had ordered thin and got thick. Not a job killer, but adds a step, that requires lathe work.
I had to put each cap into the chuck of the lathe, then using a 1/2" end mill in a tailstock chuck, then cut the top thickness from 9/16" to 1/8". After this is done with a centering jig in the drill press, the cap had (2) 1/4" hole drilled into the side of the cap, 1/4" down from the top of the cap, roughly 45 degrees from each other.
1 - the caps, the modified one on the left, the one on the right, as it came from the supplier
2 - in the chuck
3 - end mill in the chuck, with washers, stacked on it to control the depth of cut.
4 - the drill press set up
5 - gas holes in the cap, they are now ready to be installed
Name:	omya 45 007x.jpg
ID:	114381   Click image for larger version
Name:	omya 45 008x.jpg
ID:	114382   Click image for larger version
Name:	omya 45 014x.jpg
ID:	114383   Click image for larger version
Name:	omya 45 024x.jpg
ID:	114384   Click image for larger version
Name:	omya 45 020x.jpg
jack
Old 03-31-2014, 08:37 PM
GNAP - Great God of Steam,
Is the rumble just annoying or can it have damaging effects on the boiler?
Old 03-31-2014, 08:43 PM
Precision washers, I presume?
Old 03-31-2014, 09:03 PM
Like the end mill trick
Old 03-31-2014, 09:09 PM
platypus20's Avatar
Boiler God
Can be both, in this case, the stack vibrates so badly, that the windows in the plant control room shake.
1/2" grade 8 SAE flats
jack
Old 03-31-2014, 09:43 PM
4-13-1949 to 5-21-2023
How do you stop the end mill from spinning in a Jacobs chuck?
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 03-31-2014, 09:53 PM
Do the depth control washers interfere with chip flow? How are the chips removed from the hole?
Old 04-01-2014, 08:09 AM
platypus20's Avatar
Boiler God
just tighten it down and don't go crazy on the feed rate.
no, although I'm cutting (milling/drilling) about 7/16" in depth, it produces a lot of chips, so I back it out and clean off the end mill about 3-4 time on each cap. So as not wanting to break the end mill, or have it turn in the drill chuck.
jack
Old 04-01-2014, 11:26 AM
This brings some questions to mind regarding an endmill. Can you plunge with endmills? Is there a depth limit? Or is there certain types that you can plunge with and others that you cannot?
B biggest
I idot
D democrats
E ever
N nominated
Old 04-01-2014, 11:29 AM
Banned
Look at the end.
2 flutes pretty much are all "center cutting" meaning yes they will
plunge (or drill) .
4-flute (or others) look to see if 2 flutes go all the way to the center, and
the rest are trimmed back, these are "center cutting" as well.
