![]() I like the 8x24 or 8x29 ones as they have a 38mm spindle bore which strikes a knownothing like me as very useful, makes a small lathe able to handle some long stuff |
https://www.clarkedistributors.ie/in...6&search=Lathe And when sold here they are bonkers money |
![]() I had a shipment last year from China, of 530kg and it cost $300Cdn to land it in port here. And like you said, don't be in a panic. I'm sure there is a way to do this if you want to.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. One of the things my dad taught me is that the world is your bathroom -- Quick Dick McDick |
Like others have said, a tail stock is an essential item. Change gears are a pain in the ass. You will appreciate a quick change gear box.
So I saw this and thought I would ask about it...
https://www.facebook.com/groups/3593...ssenger_banner Quote:
Lathes without tail stocks are mostly useless... Personally, they are only worth scrap value.
John, I have Chicom lathe and a mill, the lathe is accurate, far better than some of the crap ones I’ve operated in various machine shops over the last 50 odd years. At the time I was looking at a Taiwanese one but this came with more goodies so I went down the Chicom path. I cut a lot of metric threads on it, until this last year I cut minimum 720 off 12x1.75 per year and it has been more than adequate. There has been an issue with the bearing in the cross slide but I replaced it easily and hasn’t been a problem since. I leave the nut engaged with all threading by habit as it is easier for me, it has an excellent foot brake.
It's So Easy |
I did a double post and it wont let me get rid of it.
It's So Easy |
Been watching the small ads for the last while. Technically I'm not ready to buy, but if a deal was to come up then you gotta move.
There's been more myfords on the market in the last few months too, some nice looking machines which are coming in at similar money to the Chinese lathes I've been considering. But today I missed out on a deal. A clean south bend with two chucks, couple of tailstock bits, boring bar, has and insert tooling for 250 euro only an hour and a half away. I saw the ad 3 hours after had gone up and it was already being collected by its new owner. One of the more complete setups I've seen in a while, for a fraction of the price of others. C'est la vie. I need to focus on getting the bandsaw onto a smaller base and build a bench over it for now |
For a first lathe, is length or diameter more important?
Lets say an 8x27 is the same price as a 10x20, and all other parameters are equal in terms of gearing, bed width, spindle bore etc. which is the better choice? I know it's a very piece of string question but curious as to the opinions and reasoning behind them. I have no specific tasks in mind for this lathe, I mostly expect it will be pins and bushes for old farm machinery starting out so most things I'll be turning will probably be less than 2x12 in reality. |
Weight. If it’s splitting hairs like that, go with the heavier machine. It’ll be more stable and less apt to vibrate or chatter.
Sent from my iPhone using Tapatalk |
