Old 08-29-2019, 10:07 PM
Scratch Scratch is offline
Default Floor truss design questions
I have these floor trusses that a builder gave me after the deal on a house fell through. They were brand new when I got them about 10 years ago, but have been stored inside since then. I want to know what they'll span and am hoping someone here might be able to help me figure that out.
They're made with 2x4 construction, with the usual galvanized connceting plates at all the joints. They are both about 27' 6" long and 20" high. I have a bunch of the top ones and 2 of the bottom ones.
I want to use these in my pole barn to make a ceiling and loft storage space above it.
I need them to be able to span 17'. Two feet on center.
Any truss designers out there?
Old 08-29-2019, 10:27 PM
What is your plan for roof trusses? Will the floor trusses be below the roof trusses?
Old 08-30-2019, 07:00 AM
Yes, this is going in an already built pole barn with 16' sidewalls. I've recently decided to section off a portion of it and want to use these floor trusses for the ceiling so I can have storage up above it.
Old 08-30-2019, 08:46 AM
Now I understand. Are you looking for load data? How are you attaching to the existing structure?
Old 08-30-2019, 09:18 AM
The building is 40'X63'. I'm building a small, 4 walled, room in the corner about 24' x 27'. The room will be attached to the posts on two sides in one corner, with free standing walls on the other two sides.
That room will be divided in half with a load bearing wall at about 16.5'. I just need to know if this truss design will safely span a 17' distance if used 24" on center.
I'm pretty sure they will as I also have another room that is using 12" TGI's that are rated to span that distance easily. I thought that floor trusses have a greater strength than TGI's, but wasn't sure and was hoping there might be someone here that knows this info.
I had a good friend that designed roof and floor trusses for a large company. He told me to send me a sketch of the trusses and he could easily tell me right away if they would span that distance. Unfortunately... that friend died a few months ago and I never got to send him a sketch.
Here's a rough drawing of what I'm trying to do. Walls in blue, floor trusses in grey.
Old 08-30-2019, 09:26 AM
I just Googled: "Floor truss span" and found this chart:
According to this, their 20" tall floor trusses can span 23'-10" if placed 24" OC. Which is more than I need since I'll be having a load bearing wall at about 17'.
This is the number I'm looking for but I have no idea who made these trusses.
Old 08-30-2019, 11:25 AM
Marked up your drawing; this is the MINIMUM I would do to use those trusses as you're intending.
Notice that the originals have a double 2x at each end? These are the ONLY intended support points (like between two load bearing walls) - if you try and use them between two points that are 17' apart, the midpoint support will collapse that section (the lower chord first) because the supported weight will be pushing down where there is no direct transfer of the weight to the load bearing wall.
Ideally, those "triangles" in that section should be changed so their end points coincide EXACTLY with the 17' support point, and another vertical added at the load bearing wall.
My drawing should work OK, but likely wouldn't be as strong as "re-designing" that one 5' section. The 6" offset is the reason I added the extra sister of that bottom chord - not ideal, but less difficulty to do than re-cutting ALL the interior chords to meet your 17' support point.
It would be better if you could move your support wall to EXACTLY 17 1/2 feet AND add that upside-down "T"... Steve
Old 08-30-2019, 01:12 PM
Ok, I see what you mean by needing a vertical in there at the support point. So if my trusses are 27.5' long, and I hypothetically make my wall at like 26', could I safely change the truss by cutting off about a foot and a half and add some pieces like this:
Old 08-30-2019, 01:17 PM
Also, hypothetically.... if I wanted to make one room, not split in half and wanted the support wall to be at like 15', could I just modify the truss to something like this and be safe:
Old 08-30-2019, 01:20 PM
Yup, that'd give you the straight vertical transfer at the supported ends of the truss - everything in between is still just a bunch of triangles stuck together, which is what makes the EFFECTIVE depth of that "board" (truss) 20", but at a lot less WEIGHT than a 4x20 solid board would be... Steve
