![]() He built a rocket stove from what appears to be 4" ID x 1/8" wall pipe. I have 4 and 5" ID casing scraps in stock that are thicker wall pipe (+/- 3/16". IIRC). Any thoughts on how the stove's performance would be affected by the extra wall thickness?
Design to 0.001", measure to 1/32", cut with an axe, grind to fit.. ![]() |
You’re radiant heat off the pipe will take a little longer as it has more mass to warm first, once it’s warmed up should be similar. It will also take a little longer to cool off when you’re done.
Wonder what a hair dryer/blower would do to the performance? ![]() Sent from my iPhone using Tapatalk |
As to the hair dryer I think the whole idea of a rocket stove is that they're designed to create their own draft. They're meant to create a fast, hot fire for cooking rather than producing a slow, steady heat for warming a tent or enclosure. My take on it, anyway...
I'd hate to have to split a cord of wood that small. OTOH you have enough caragana hedge to provide small bits to heat your shop for a long time.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. BLM has proven to mean Buy Large Mansions The virtue is always a cover for the sin. That's the key to understanding the modern left. Whatever they're accusing you of doing, they are doing themselves but more enthusiastically. And that's definitely the story of Justin Trudeau. Tucker Carlson |
A lot of work for a cup of coffee. Now, if it was for a cup of hot chocolate?
Chris One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors. Plato LET'S GO BRANDON!!!! |
With the leetle mini marshmallows ? or not ?
More form than function... Really you need a screen and clean out door for
something that tiny that you can turn upside down and shake out? Too much form vs. function and no KISS...
Also his tapers were backward for proper flow through a rocket nozzle, first convergent then divergent. But wtf, its pretty...
Oh and dude invest in a plasma.
