Old 04-19-2006, 05:33 PM
ross ross is offline
Send a message via AIM to ross
Default Silicon Bronze TIG?
Does anybody have expirience doing sibr welding of 304 ss to mild steel? The application is a turbo header for a 4 cylinder, and I'm trying to keep the flange from warping tooo bad.
Old 04-19-2006, 07:57 PM
Jerry Jerry is offline
You could try welding with 309 and place flange in water, then weld a little and so on to minimize heat input. I have welded parts in such ways to prevent warping. If I'm patiant enough usually works well.
Silicon Bronze welds good to almost all metals. I've welded on galvanized ,CRS, HRS, stainless, copper, bronze, brass.
J P Streets Welding
