Old 11-25-2007, 09:47 PM
1vegoil
Do you have any idea what size your door will be. It was after dark by the time I got done with the 350 ton crane and I didn't get a chance to take any pictures. I can whip you up some drawings if you can get me the size. The opening size that is. Mine is powered with a commercial garage door opener. The type that has a brake on the outside. One section has to be taller than the other so that it won't go past center and fold up on you. I have 2 - 1/4" cables that pull it up. One is more than sufficient the second is saftey factor.
The frame is made from 2x4x1/8 tubing for the perimeter and 12ga. tube for the internal braces. With formed 1 1/2" angle for purlins I guess you would call them. The frame doesn't need to be real heavy. With the sheetmetal screwed to it, it aquires a lot of strenght. I also glued 1" foam insulation with the foil on both sides to the inside for insulation.
I am working out of town for the week. 3 hrs. from home. I won't be able to get you any pictures until the weekend.
Hope I can be of some help.
Old 11-25-2007, 11:03 PM
1vegoil 1vegoil is offline
Default size
the opening is 14 foot tall 20 foot wide...how did you use a door opener?? i was wondering about the sections being equal..all of my research says they can be and it will never fold over but i can sure see the bottm pulling under the top in my mind?? jeff
Old 11-26-2007, 08:47 AM
randydupree's Avatar
Why, Hell Yes!
go to www.bifold.com
there some nice stuff on there,you can see how the opener works too.
they are using flat straps to lift the door and thats what i'm going to use.
to stop the door from opening to far you can weld a stop to the door jam or make the top door smaller,
Randy
Old 11-28-2007, 12:43 PM
Default just a bump
Just a bump to keep this alive...Jeff
Old 11-29-2007, 09:52 AM
Why, Hell Yes!
i just put some pics on my "building a home" thread of my bi-fold door.
check them out.
Randy
Old 11-30-2007, 08:39 PM
Default bump...
just waitin for theweldor to get home and fill in the blanks...
Old 12-01-2007, 01:31 PM
1vegoil
Here are some pictures of my door and opener. If you have any questions please feel free to ask.
Bob
ID:	25334   Click image for larger version
ID:	25335   Click image for larger version
ID:	25336   Click image for larger version
ID:	25337   Click image for larger version
Old 12-01-2007, 01:38 PM
Here are some more.
ID:	25339   Click image for larger version
ID:	25340   Click image for larger version
ID:	25341   Click image for larger version
Old 12-01-2007, 02:08 PM
JimNColorado's Avatar
JimNColorado JimNColorado is offline
Weldor, That is a clever opener. Bet it works well.
Jim
"When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there's no end to what you can't do. "
Old 12-01-2007, 02:34 PM
Why, Hell Yes!
is that boomer just a lock or does the door not completely close in the down position?
some bi-fold doors don't seem to close all the way at the part line, where the hinge is.
i'm wondering how to overcome that little glitch!
Randy
ohh,nice door!
