Old 03-30-2005, 09:34 AM
DF5152 DF5152 is offline
Default blade TPI
ok I know what it means but what are the applications? more or less teeth, which is better, and for what material?
Lincoln SP170T
ESAB 875 plasma
14" cold chop saw
Dynasty 200DX
O/A setup
New mig on the way
Dan's Page
Old 03-30-2005, 09:52 AM
Wyoming
Guest
Posts: n/a
While there may be some reference to what material you would use a particular TPI count on, I believe that it is more often the thickness of the material being cut that calls for a particular TPI. Thinner material would need a higher count TPI in order not to jerk the workpiece out of the vise if the sawtooth should bind on the edge of the work. Likewise, a thicker workpiece benefits from having a lesser TPI blade being used in order that the tooth gullets may clean the excess filings from the cut and keep a cooler metal-to-metal contact at the cutting area. There is a thread somewhere on the site that discusses this topic with much greater detail, but I haven't found it yet. I believe it was stated that for best results try to keep 3-4 sawteeth in the cut at all times and you'll have about the optimum count going for you.
