Old 06-17-2021, 06:33 AM
Originally Posted by toprecycler View Post
Nice finds.
Hope the grinder works.
I haven’t tried it yet. All too often the power cords are cut off from the power tools at the scrap yard as this one was. I did notice the treads on one end of the spindle are largely destroyed but there is five or six on the end that are not. One could place a spacer (stack of washers) to take up the damaged area.
In any case I have numerous other wheel grinders from the scrap yard.
Below is a picture of the one I got about two months ago. It is an older Black & Decker 10”, 1 HP, 3 PH. I runs great but is missing one of the rests. A great buy for $9.
Also shown are piles of tube/pipe cutters, hex key wrench sets and flint strikers. Most are spanking new all had for about $2
Old 06-17-2021, 06:34 AM
Forgot the picture.
Old 06-17-2021, 09:08 AM
You got a heck of a nice relationship with your scrap yard.
Old 06-18-2021, 02:48 PM
Definitely one man's trash is another man's treasure!
TA 95 lunchbox w/tig
Old 06-18-2021, 07:20 PM
We used to have one that I called the bank.
You could take as well as drop off, the yard guys gave me some nice metal shelves one day.
Just make sure you weigh less going out.....
Old 06-22-2021, 09:33 AM
Sberry's Avatar
Sberry Sberry is offline
GOD of Strawberries!!!
There is a plant here, can get graded for 20 a ton. I get it in pallet boxes.
Name:	sand pot door.JPG
ID:	160784   Click image for larger version
Old 06-30-2021, 05:53 PM
staybusy staybusy is offline
I have a similar setup my friend gave me for free.
You need a really powerful compressor to run it effectively. If you don't have that I'd suggest using a "sand blaster gun".
You can make your own for dirt cheap if you have a spare air blower around.
Old 07-12-2021, 06:45 AM
Originally Posted by midmosandblasting View Post
The reason not to use sand is health Sand is not expelled from the lungs . Causing a illness very much like Black Lung . A lot of blasters still use as it can be had for 50.00 per ton dry and sized where as Black beauty or glass will almost run .20 per pound .Prices may be a little off as I have been gone from it for 15 years . .
Indeed, however I don’t think this is the reason for the label on the blaster.
I watched a video of a fellow describing the performance of the same blaster. This guy was using some type of sand/abrasive. He showed that a hole had been worn through the mixing device at the bottom of the tank after only a few hours of use.
Old 07-12-2021, 10:16 AM
Yep a blaster ,one of the few tools that wear themselves out . Mixing area ,even on a clemco is only good for about 500 hours .
