Old 05-13-2007, 03:23 PM
Default No moving parts HVAC well really just the 'V'
Well I burned up another ventilation fan for my hot work bench/fixture. So I have been thinking that a set up with no moving parts would be ideal my one job involves welding on parts that have residual stamping oil left on them we can weld through the oil but if generates alot of smoke. So combined with the smoke eductor I vented it outside as well. I was not thinking when I first started it or I would have taken more pictures.
Inside is just a 1/4" pipe Tee you can see the 1/4" nipples sticking out the sides. The elbow and cap are aligned with the outlet of the Tee so I know the position of it just incase it gets out of alignment.
In the Tee is a pipe plug with a #52 hole drilled in the plug for a nozzle.
I works well with 10 PSI of air you can see the KISS plumbing on the A/C I just got around too....
ID:	23257   Click image for larger version
ID:	23258   Click image for larger version
ID:	23259   Click image for larger version
ID:	23260   Click image for larger version
Old 05-13-2007, 04:08 PM
boilerman's Avatar
boilerman boilerman is offline
SFT Brewmaster
how about trying a wind turbine roof vent on the end ....only have to use the air ejector on calm days ...eductors are for water
Director of Recruitment, Overseas (by appointment)
I don't suffer from insanity...I enjoy every minute of it
Old 05-13-2007, 06:03 PM
LW Hiway's Avatar
LW Hiway LW Hiway is offline
Lord of the Minions
Looks to be a slick way to vent the work for sure. Nicely rigged.
Would it be possible to have a pic of work in progress to demonstrate the venting in action?
Old 05-13-2007, 07:01 PM
Yup....
Old 05-13-2007, 07:51 PM
RED caddy's Avatar
10-28-1951 to 4-19-2021
Da Chief
Ron, you can conserve a lot of air, without a drop in performance, by putting a pipe plug in the "T" with about a .100" in. hole drilled in it. RED
Old 05-13-2007, 07:56 PM
Bolt Bolt is offline
So a venturi effect creates enough vacuum to suck smoke out the pipe? Very slick setup.
Old 05-13-2007, 08:24 PM
IHdonnie IHdonnie is offline
Old 05-13-2007, 09:35 PM
A #52 is a .0635 size hole, even smaller.
