Old 03-09-2020, 09:17 AM
I'm running low on popcorn
Here I'll share.
Old 03-09-2020, 09:42 AM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
Okay, I need popcorn too.
I totally missed the first thread on this copper weld issue. After reading that thread, I guess I jumped to a faulty conclusion with DD's post.....sorry 'bout that.
Old 03-09-2020, 10:01 AM
JavaKing JavaKing is offline
Sorry...I am far enough away, even if it is "downwind"....
Maybe Tim can go over there and provide instruction, moral support, or sumthin'....
Thanks for all the advise, and will go with Harris Stay Silver15, and yes new project 3/4 copper coupled to 7/8 copper tubing, and not to interesting
Old 03-09-2020, 10:18 AM
old iron old iron is offline
Maple syrup I have, so why all of a sudden I have this craving for popcorn?
So do you have the vacuum pump and gauges to refill the system?
Old 03-09-2020, 10:33 AM
Naw.....just go to AutoZone....easy peasy....
Old 03-09-2020, 10:50 AM
Just to drag a smelly dead fish across the trail.....
Yesterday after some prick zip disk'd the cat converter and O2 sensors off a pickup truck, they also nicked the trans cooler line. In one spot it was cut deep enough to leak.
I managed to crawl under it and after the line was disconnected and blown with air, I cooked it with a propane torch til the oil was burnt out.
Then I used this rod and the bernzo torch to silver solder the damaged line. It holds pressure and the guy is happy.
Old 03-10-2020, 05:19 PM
Just by standard flux coated brazing rods, attach a jumper cable to one end,
the other cable as a ground to the pipe.
try a 12v car battery.
Old 03-10-2020, 09:50 PM
LKeithR LKeithR is online now
Too high tech for me...
Old 03-11-2020, 03:05 PM
yes, that is a easy one, thanks for all the smart advise
