Old 03-08-2020, 11:40 AM
JavaKing JavaKing is offline
Default brazing copper tubing need rods
I need a good rod that I can buy from Amazon, for brazing 3/4 copper refrigerant tubing, I will be you using hand held map gas propane bottle with a very good torch head.
Old 03-08-2020, 12:24 PM
Based on your last thread, please hire this out.
Old 03-08-2020, 12:50 PM
Its been a long time so also search the web and check my recommendation.
IIRC, you want Harris STAY-SILV 15 (Silver Brazing Alloy)
If this is for drinking water be sure to read the safety notes as some silver-solders were outlawed for drinking.
I have some silver-solder that states Cadmium free so maybe it is Cadmium that it bad.
The 15 is likely 15 percent silver.
IIRC: Copper to COPPER you do not need flux "but" the copper you use must be very very clean.
Also: you do not use the flame to melt the silver-solder the copper need to be hot enough to melt the silver-solder on its own without direct heat.
at the same time if you over heat the silver solder and it starts to bubble a lot it will contaminate the joint and you will have to start over and clean the copper.
Old 03-08-2020, 12:57 PM
Again, if the torch is not jetted for Mapp gas it may not get as hot as a torch properly jetted for propane.
Old 03-08-2020, 02:16 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
....somebody step on your tail again?
Old 03-08-2020, 02:43 PM
Please read Shade's response in the "other thread".
Old 03-08-2020, 02:51 PM
https://www.amazon.com/Aufhauser-Sil...3697036&sr=8-5
Please report on how this disaster, err Project turns out...
Optional flux
https://www.amazon.com/Harris-SSWF1-...6WN6X3VF9VBC3T
Old 03-08-2020, 02:52 PM
Dougie, shhhh!!! this could be entertaining.
The last thread was 1" tubing now it is 3/4" tubing. This could be really good!!!
Old 03-08-2020, 03:09 PM
Sorry...I am far enough away, even if it is "downwind"....
Maybe Tim can go over there and provide instruction, moral support, or sumthin'....
Old 03-08-2020, 03:14 PM
You're always downwind, because New Yawk sucks so much...
