Old 02-26-2020, 12:44 PM
MrCrankyface MrCrankyface is offline
I can only dream of something of that size!
Here's what I ended up doing instead of welding ...
Now I just need to hook them up to the system!
I will also add temperature sensitive cooling to the compressor now that it has some more volume to fill up..
Old 02-26-2020, 02:30 PM
how will you drain the water from those tanks?
Old 02-26-2020, 02:51 PM
I'm coupling both drains to a T-piece and running a hose back down into the shop then I'll manually go up and drain them every now and then.
There's 2 water filters in the way before these tanks so I hope they shouldn't see much moisture at all.
