Old 02-07-2017, 07:09 AM
tansit tansit is offline
Default Idle hands at the CNC
I cooked up a little 60 minute timer mostly out of boredom but also because I keep forgetting to turn my coolant skimmer off and flood the floor with sludge.
All Home Despot parts put together my way starting with a 1/2" single port PVC box, calipers, Google-fu, and CAM software. The engraving was done by text and also taking a clean picture of the faceplate and messing with a jpg to dxf converter and importing. I modeled the basic shape as a solid and made three centered work offsets.
And yes it's really 10A because of the C13/C14 connection's limits. May add a push button breaker on top if I find one floating around.
ID:	137750   Click image for larger version
ID:	137751   Click image for larger version
ID:	137752   Click image for larger version
ID:	137753   Click image for larger version
Cleaning: The act of hiding all your possessions in different locations for false aesthetic reasons so that you may not be able to find them again causing you to go out and buy items you know you already have.
Old 02-07-2017, 08:40 AM
alchemist's Avatar
Looks good. I really like the ingraving. Do you have any pics of your machine?
Old 02-07-2017, 09:51 AM
The mill is just a typical Haas VF-7 / 50, model year is 2007. Has 5 Kurt D810's, Rennishaw, and 1000 psi coolant. 84"x 32" XY travel. About as strong as a small 40 taper Mazak sadly.
Old 02-07-2017, 11:17 AM
Nice work, Tansit.
We who have no CNC mill cannot sympathize with you having a weak one
Old 02-07-2017, 07:47 PM
cramd's Avatar
cramd cramd is offline
Drivin' Fool
Nice work, Tansit.
X2............looks really nice.
Miller Thunderbolt XL AC/DC
Hobart Handler 190
Old 02-07-2017, 10:08 PM
Not sure why I got to thinking about this picture.
Old 02-08-2017, 02:27 PM
I'm not sure either, Tan but I suspect it has something to do with genetics.
Old 02-08-2017, 05:20 PM
TEK's Avatar
TEK TEK is offline
That would be a safe bet, USMCPOP is always coming up with pertinent and applicable data, from somewhere. ..
-----DozerDan
Old 02-09-2017, 11:04 AM
Do I have a life?
Good job, Tan!
BTW, I know of an old grizzled Navy vet looking for some spiral fluting work on a couple? 16" barrels. I think he posted about it in this category somewhere... Might be a good side project if you're THAT bored.
HF 80 lunchbox w/tig
Old 02-10-2017, 02:06 AM
TEK's Avatar
TEK TEK is offline
Good job, Tan!
I believe he said some straight ones as well. Said he could hide them under the handguard.
This raises a question for me. Is there any benefit of one type over the other? Is there any strength difference or performance difference between the two types?
The voices in my head are saying that the straight flutes are more rigid.Is that correct? ...inquiring minds and all that. ..
-----DozerDan
