![]() https://www.ebay.com/itm/Hydraulic-P...53.m1438.l2649 |
Should work fine explain more what you mean by wheel lift tho?
Just noting 1,600 - 3,000 watts ......... I assume the motor need.
may need to add battery's for more power.
I'll need to hook it to a 3 spool control valve |
We, ran a lot of units like that on dump bed stake bodies when we were a Mom & Pop. No, need for an extra battery.
good point. it's a 7.3idi so I have 2 batteries now
Oh, you should be golden with that. Set it up with an open center spool valve and an on off switch versus a momentary on a dump bed app and cycle away. It will just run no-load until you run the lift. OK the one issue I see on further thought is the pump combo you posted has control valving. You could block the valve open going one way into your spool valve or find a simpler one probably cheaper with no valving and just a pump and reservoir.
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill Last edited by Whitetrash; 02-20-2021 at 09:09 PM. |
Do I change out the push button controller for an on/off switch then run continuous to the 3 spool valve?
I just edited my last post to cover what you are asking about. You don't need valving on your pump unit if you are running through an open center spool valve. I would also suggest your spool assembly has a relief cartridge to prevent damaging pressure spikes.
