Did it fail when powered and frozen ?
Is there a groove worn from a seal or bearing failure ? You would be surprised how the charpy numbers of some steel drops off at 20f. |
we assume it failed when running. The wash water failed early on but the unit showed operational. I assume the ice was formed by the nature of the debris and the dewatering that the conveyor naturally does due to the incline. The run indicator gets signal from the starter so we dont know exactly when it failed.
13f was way cold for this area. I've only seen this temperature back in the late 80s. it was 9f then. The maintenance supervisor and myself will have to figure out whats the best way to keep this from happening again and write that into our emergency operations plan. other than busted piping this appears to be our worst mechanical damage. |
Most plants here have all the ‘water’ components double jacketed, then insulated. The outer jacket is heated with steam or hot water, and through valves and controls the temperatures can be regulated for use. Maybe in your case a double jacket for air that can have a salamander or something installed for cold weather would work? Sent from my iPhone using Tapatalk |
Is this a flat top auger? If so the shaft stubs are often hardened to be used in the chilled iron hanger bearings.
Perfection is the enemy of good enough. |
I have seen the "shear shaft" and so have most of you. Next time you unbolt a hydraulic pump, look at the necked down shaft area next to the seal. If the pump seizes up the shaft twists off there, and does not destroy the drive gears. Even Roosamaster injection pumps have this feature internally before the high pressure pump section. In this case I am sure the shaft was ready to fail and the cold snap just made it earlier. On a gear reducer, as digr said, never heard of such a thing.
Looks like only 13f this time, 9f late 1980's. Sad to say, it looks like we are improving....but don't want to let that out eh ? |
