It would solve my rotational direction problem for sure. But it creates some space consuming issues (the unit gets wide) that will not work out in my application. However as it turns out there may be a way to either buy or machine a PTO on the flywheel side of that motor which would facilitate turning the engine around without having to offset the compressor and engine....... I'm heading out to the shop shortly to check out the possibility. It is -26C (-15F) with an upwards of 20mph wind Here right now so going outside for the trek across the farmyard to the shop either requires a sprint (hell no! lol) or a few extra layers. |
I have a Quincy running "backwards" for years now. I was concerned with cooling as the inter-stage cooler is right by the flywheel and it could nor be turned because of the taper. So I monitored it with the heat gun for a while, and it never got the cooler very hot by sucking air across it instead of blowing as they intended.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. The virtue is always a cover for the sin. That's the key to understanding the modern left. Whatever they're accusing you of doing, they are doing themselves but more enthusiastically. And that's definitely the story of Justin Trudeau. Tucker Carlson Last edited by Ironman; 02-14-2021 at 06:32 PM. |
turning the flywheel around will not reverse the air flow
Drawing by Smartdraw |
Lol... Insert head smack here! Your right. Id need to turn it inside out. That's a tricky procedure!
The flywheel side PTO is an option but it looks like getting one will be tricky. I could spend a day or so on the lathe and machine one... but the lazy side of me is kicking in cuz this was supposed to be a quick and dirty project. |
Tags |
webster c83 compressor |
