Old 02-05-2021, 07:47 PM
I determined the cause of the cracks to be force from the crankshaft after being dropped.
I discovered the rear bearing cap/unloader assembly was separated from the case of the green pump. The blue pump was undamaged.
The crank pushed out the bearing cap and the threads of all four tapped screw holes that secure the cap. It also cracked the case in a few areas shown with white paint dots.
ID:	159448   Click image for larger version
Old 02-05-2021, 10:01 PM
I am in need of help to understand what you mean here......... Oh! I got it before I hit the submit!
How about adhesive type wheel weights?
In reality though I believe this is not a balance issue and adding mass will make matters worse. Adding mass will primarily act on a force in a radial direction. The runout is acting on a force primarily in an axial direction.
Axial run out it won't help. I was thinking OD.
Old 02-05-2021, 11:59 PM
I
Very weldable.
locate and drill a hole at each end of the cracks
Vee out the cracks and weld with nickel.
Old 02-06-2021, 06:29 AM
Yes, the definition of runout and concentricity gets blurry to me when when the details and specifics of their meanings are exposed. For me runout is deviation on a radial plane or axis. Concentricity is deviation from a center axis. Anything more is beyond the scope of anything I do.
I actually failed to check for concentricity. Your suggestion to add mass might apply.
Old 02-06-2021, 06:51 AM
Very weldable.
I never used nickel. Would that be considered more like brazing rather than welding? I have various “rods” but I am unsure what they are. I suppose I will find one that cooperates the best and use it. I’m not too concerned about strength here. I think it may be possible to do a thread repair on the four holes,
reseal the inside with epoxy and call it good.
I have done a bit of research and concluded I don’t want to melt the base metal (cast iron) as in welding. There seems to be more issues to consider when welding such as elevated preheat temperature, cool down time, hardening and shrinking stress. All of these concerns seem to be reduced when brazing at lower temperatures.
Old 02-06-2021, 12:26 PM
You can braze with brass. Still takes a lot of wide spread heat to braze. Nickle also requires a good bit of preheat as well. Nickle rod is pricey where brass is much lower in cost. The heat on cast is not the issue. It is the cool down to control on cracking. Slow cooling is the key.
Old 02-08-2021, 07:22 AM
The brazing is done. We shall see how complete the filling is when I drill and tap the holes. Those areas were a bit of trouble.
After soaking the block in my electric oven for four hours I placed it in a wheelbarrow, covered it with a leather welding jacket and made the forty yard trek uphill with five inched of snow on the ground and a temperature of 15 degrees F.
I removed a storm windowing the kitchen and placed a fan to pull out the smoke from the burning paint.
ID:	159469   Click image for larger version
Old 02-08-2021, 10:06 AM
Bet you are a popular fellow if that electric stove was in the kitchen .
Old 02-08-2021, 10:09 AM
Good thing you are single , or you would soon be after using the kitchen oven.
Old 02-08-2021, 12:07 PM
It looks very nice, should cause no problems. You'll have to file the brass out of the register circle. It occurred to me that you could rotate the bearing cap a few degrees to drill into fresh meat for the bolts. There is usually gaskets used for bearing shims so you may have to re-adjust bearing end play.
