Old 02-02-2021, 07:11 PM
Ironman Ironman is online now
Default Need a source
I am looking for a source for multi-rib belt pulleys. This is also known as a serpentine belt for cars.
There are J,K,L,M profiles. J profile is the common industrial multi-v belt. K is the automotive multi-v profile.
Last time I had to do this I made a 13" pulley for an 8 groove belt, for a K belt which is the standard automotive belt. The biggest pain is rolling a piece of 1.25 x 1/2" stock into a semi-true circle and centering and welding it on a plate.
After that it is just machining.
So I'm looking for an easy way out.
Old 02-02-2021, 07:41 PM
How many belts/pulleys you need? Diameter and bore?
Old 02-02-2021, 08:24 PM
Only one for 8K belt at 11 inch OD, and the bore is a taperlok and I forgot the taper size, but it goes on a 1.5" shaft.
Old 02-02-2021, 09:30 PM
Are you talking "Poly V" belts, Gerry? Browning was the originator of the design but I'm sure there are other manufacturers out there now. I have a Browning catalogue but it's at the shop. I can look up some part numbers tomorrow if you want.
There must be a number of power transmission outfits in Edmonton. I'm sure Motion Industries will have a warehouse there. Almost certain to be other local sources as well...
Old 02-02-2021, 09:39 PM
ShawnR ShawnR is offline
I think you can get them from Wajax. Here is the local store but perhaps there is a store near you? You can probably dig around the website to find the nearest one.
https://www.wajax.com/location/thunder-bay/
Another place I have used are bearing suppliers like
https://www.canadianbearings.com/web/
Good luck
Shawn
Old 02-02-2021, 09:51 PM
camdigger's Avatar
Roving Reporter
Last time I was looking for a specialty belt, I talked to these people https://transmissionsupplies.com/
Old 02-03-2021, 06:14 AM
Sorry Gerry
I read that wrong. I was thinking belts...but either place might be able to access pulleys too...?
Shawn
Old 02-03-2021, 09:55 AM
Originally Posted by ShawnR View Post
Sorry Gerry
Shawn
Not a chance, you'd have better luck buying a metric twist drill in a hardware store.
Old 02-03-2021, 10:00 AM
Pol-v and Multi-v are trade names, Gates owns Multi-v.
Motion says they can't supply as of yesterday. One of their employees told me they could order them from Browning, he thought. But only J profile.
I have found them only up to 4.2" diameter for driving alternators at where I got the chart.
Name:	Belt Micro-V sheave specs.PNG
Old 02-03-2021, 10:27 AM
Quick search pulled this up. Maybe this will help you search more
http://www.industrialbearings.com.au...1327992533.pdf
