Drained the muck. Shaft between the clutch and shuttle shift box is a bit loose. Can move the shaft in the bearings. Considering what I paid for it I think I have a plan B that won't involve splitting the tractor and should keep things goimg long enough for me to get my jobs done.
The bearings are open ball bearings. Pack with grease. Coat all gearing with grease too. Change the bad tire and run it. If like to find what they use on the open gearing on traction engines. Seems pretty sticky versus normal grease. At a later date I can tear into it properly.
Tim Self appointed director of junk, and old vehicles. |
Update...
Got a new rear tire on the way. Should be here tomorrow. Also replacing the radiator. Pretty good leak in the original.
The new tire just doubled the value of it.
Got the tire off Tuesday evening. Also put some 4x4 blocks under it after I was done. Did it in the rain. But got it done.
Got a case of jt-6 grease and a bucket of open gear grease on the way.
With all that indoor space, you did the work in the rain?
Make over, make do, or do without Why do I have to press one for English when you're just gonna transfer me to someone I can't understand anyway? Grant me the strength to accept the things I cannot change, the courage to change the things I can & the friends to post my bail when I finally snap! |
Im not ready for spills on the shop floor lol
Got the tire mounted with a new tube. New radiator is in too.
It's got to be baptized sometime.
I think all of the dirt on the floor will quickly soak up any spills...
![]() How is the other side? Click and Clack used to joke about the "avalanche of envy" used parts have for a new part and will soon fail out of jealousy. ![]()
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) TA 95 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... |
