I have cut threads on many different lathes over the years and, for whatever reason, I've never trusted
the thread dials--my current lathe doesn't even have one. I always thread by selecting the correct pitch in the gearbox, engaging the leadscrew, making a pass, stopping the lathe, backing the tool out a bit and reversing direction without disengaging the leadscrew. It really doesn't take any more time and it ensures that you get accurate threads every time. Give it a try and see what happens...
check the pitch of the lead screw maybe its metric, and you are trying to cut US threads.
we had one member with a Jet lathe that had the wrong gear on the thread dial. place a travel dial on the carriage and rotate the spindle by hand and count the spindle rotations within 1" of travel.
Leadscrew pitches are generally coarse enough that even if you don't have an acme pitch guage an ordinary 60 degree guage should enable you to figure out what your pitch is...
GWIZ, I do believe I have a metric leadscrew. Everything on the machine is metric but the charts give gear combinations for imperial threads. At this point, I don't care what the thread is. I think the procedure would be the same and I think my main problem is the inconsistency of the tool hitting the work piece. I will try to shoot some over head video tomorrow. Maybe I will catch myself doing something that I don't think I am doing....
Keith, I have seen postings on that procedure. I have been avoiding it just cause I wanted to be able to do it the "usual" way, but no one can argue that it would ensure accuracy. I may need to go that route. Probably not as bad as I think. Thanks for the input |
The other clue as to whether you are mixing thread systems between the work and the lead screw is to look carefully at the gear train at the end of the headstock. If there is a 127/120 gear pair in the train, you are mixing metric with inch and your thread dial is useless. The 127 tooth gear is the translation gear between metric and inch. I understand some lathes use 63 tooth gears to save space, but those would likely include more error to the thread pitch on the work. IIRC, the parts list in the manual you posted does include a 127 tooth gear.
Design to 0.001", measure to 1/32", cut with an axe, grind to fit.. ![]() |
As I said before I've never used a thread dial on any lathe I've ever run. The old fellow who showed me how to thread 40+ years ago did it by reversing direction--I picked up that method and have never used anything else. Threading by reversing is not a "compromise" but a good alternate method. For example, if you're cutting metric threads on an imperial lathe you have to leave the leadscrew engaged since there's no way to consistently pick up the threads...
I'm guessing his machine will track metric (metric lead screw) But he will have Issues with US threads not tracking as I recall some will, some will not.
* * The factory of the future will have only two employees, a man and a dog. The man will be there to feed the dog. The dog will be there to keep the man from touching the equipment. ~Warren G. Bennis Last edited by GWIZ; 01-31-2021 at 07:05 PM. |
Forgive me if I am stating the obvious. There are two ways to move the carriage with the gear train. One way is to engage the half nut below the cross slide, the other way is to engage the threading lever towards the tailstock end of the carriage. Only the threading lever synchronized with the threading dial will pick up the correct start point.
