![]() Anyway... since I can't find a wiring diagram for it, I'm hoping someone, here, can help me out in determining how to hook a capacitor to the start winding, so it will start and run on application of power. I think I have determined which wires go to the start winding, but am not sure. Photo with measured resistances is posted for info. A schematic drawing will get me to where I want to be. Thanks. |
you have to post a picture where D and E come from.
I assume "0" is a no reading ?
* * The factory of the future will have only two employees, a man and a dog. The man will be there to feed the dog. The dog will be there to keep the man from touching the equipment. ~Warren G. Bennis Last edited by GWIZ; 01-27-2021 at 07:57 PM. |
Here's the picture... and, yes, "0" is no reading.
this is not going to be easy.
Check you readings see picture. c=coil c1 + c2 = total resistance of the two. your total is not right A,D (6.4 ohms) If A,D is 6.4 I would assume coils c1, c2 are 3.2 ohms each.
As I try to make sense of the schematic, and, since I assume it's a 2-speed motor, I wonder, if DE is one speed, and AE is the other. That would leave BC as the start winding... maybe, perhaps? I'll keep going, until I solve the riddle. Last edited by Gadgeteer; 01-28-2021 at 04:39 AM. |
depending on the mfg
it may be a reversible motor |
A-E = 4.8 D-E = 3.1 AD should be 4.8+3.1 = 7.9 not A-D = 6.4
I was trying to see the grouping of the coils but your first picture is dark and your second is slanted 1) see picture, single speed motor. note how the 4 run coils are grouped and where the 4 start coils are in relation.
Might be simpler to just replace the motor.
I've got a brand new motor, but where's the fun in using that? And, I'm saving it just in case the furnace motor goes to sleep.
