![]() Before I posted a thread on the ball turner, cause I am sure I will have questions, I did a search for ball turner on this site and found this one. Cutter made the exact same one, (which answered another question I had as to where I got the plans. I frequented Steve Bedair's site back then. He was, as Cutter states, a good craftsman and nice guy. ) Cutters thread https://www.shopfloortalk.com/forums...ad.php?t=20687 Thanks cutter for the great write up! When I get to work, I am sure your input will be utilized! My stage below. The picture shows both projects but for now, I am going to focus on the turner. I think the square block in the box is actually for the tap handle Last edited by ShawnR; 01-24-2021 at 11:54 AM. Reason: more info |
The ball turner looks like a good project, not sure about the Tap handle above a 5/16" tap.
I just went back and read Cutters thread. I "invented" a way to do an "almost" full ball in one setting. It involves offsetting the tool bit. I think I've posted some of the info. several times on various BBs but don't remember if I've ever done so here. I have many pictures, probably hundreds, of that sort of stuff I did at the highschool shop over the 20 years I spent there as a volunteer. So if anyone is really interested I may try to collect all the stuff regarding Ball/radius turning in a folder and make it available via a "File Transfer" place. I just looked and there is over a Gig of stuff from the high school with 40 some Meg of the Ball/Radius turner.
...lew... |
When I started making it, I said "Holy crap, when am I going to use this?" ![]() But, it is a project. It was one of the options for the course. I will take a photo with the other one later. That will become another thread. I need input already on where to go next. Thanks Shawn |
Thanks Shawn |
I made some progress yesterday. Found out that Chinese tool stuff can be frustrating....but causes me to check tools as well as set up.
This one is slightly different than Cutters as it has an insert for the cutter. Here is the photo of the set up to drill the holes in the body to hold the tool holder. I did not get to drill them yet as I was having a brain fart as to why the center did not look like center. I realized that i used an edge finder on one side of the body but then had to move the body the other way to get it under the spindle and my math went the other way. ![]() And the insert holder part is coming up. My question for today is how do I cut the angles (bevels?) under the tool bit? I am thinking that to just clamp it in a vice is not enough, or is it? I have 123 blocks. Should I use them to clamp the piece, to the table, at the angle I need? Or....? I don't have sine bars. Or clamp it in the vice and rotate it to the angle...came up with that as I was typing.. Suggestions appreciated. Thanks Shawn Here is the comparison in tap wrenches I mentioned earlier. |
Tapping handle looks good so far.
This thread would look good in the Machining forum
I kinda wondered that when I started it. If the moderators moved it, ok with me.
Thanks |
Tags |
ball turner |
