![]() ![]() ![]() On a positive note, I think the crane would survive the fall should it detach! ![]() ![]()
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) TA 95 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... |
I'm even farther from being an engineer than mccutter,
![]() But my question would be, what kind of lift weight are you planning to lift?
Let FAITH be bigger than your FEAR. ***** Pray like everything depends on God, and work like everything depends on you. ***** The world is changed by your example, not by your opinion. --St. Mother Teresa ***** In life it's important to know when to stop arguing with people and simply letting them be wrong. |
There is a fulcrum near the middle of the mast where the support struts are attached. Below this fulcrum the mast will be loaded horizontally, away from what is being lifted. This horizontal load will put the wall in tension. Not good. Moreover I would have liked to see some cushion between the steel and concrete like rubber or polyurethane. The hard steel on concrete can create a stress riser that can initiate a crack. Also not good. The hoist should be sized to the structure it is mounted to so there is no chance of overload.
With the amount of energy that is being consumed I expect most people on earth should be living in Utopia. And now this? It started hitting the fan in the 1950's https://m.youtube.com/watch?v=nRnNDkHb0MU A technologically advanced society would teach their children how to start a fire by rubbing two sticks together before teaching them how to use a lighter. If you are not having fun then you are doing it wrong. Last edited by threepiece; 02-11-2021 at 01:54 PM. |
While I'm "acting" like an engineer, I'd like add that I think it would've been very beneficial for the vertical post to extend a bit (several feet) higher than the boomer leg & winch. That would have given room to attach a brace or two to anchor back away from the lift side to anchor points on the roof. (out of the swing of the boomer leg)
Hey....this backseat driving is kinda fun. ![]()
With the amount of energy that is being consumed I expect most people on earth should be living in Utopia. And now this? It started hitting the fan in the 1950's https://m.youtube.com/watch?v=nRnNDkHb0MU A technologically advanced society would teach their children how to start a fire by rubbing two sticks together before teaching them how to use a lighter. If you are not having fun then you are doing it wrong. |
