Old 11-05-2020, 11:29 PM
staybusy staybusy is offline
Default Shop Press Polycarbonate Shield
What's the standard thickness of a polycarbonate shield for a 100 ton shop press?
Old 11-06-2020, 12:01 AM
Most of the shields I've seen are metal mesh. Does your Worker's Comp office by chance have any specs for shields? They may have guidelines and/or regulations. If you use Lexan I would think that 3/8" would be enough but it depends on whether or not the press is ever going to be inspected...
Old 11-06-2020, 12:35 AM
It's a homemade press that will be in my backyard shed. I'll mainly be using it for forge welding and not quite sure what else.
Old 11-06-2020, 11:11 AM
Whose standard? East German? Africa? India?
Here in 'Murica, we gauge thickness by the fractional inch.
Old 11-06-2020, 11:13 AM
I have never seen any form of plastic used anywhere near a forging press.
Ask Allescense.
Old 11-06-2020, 12:40 PM
Expanded metal is what I used on mine and I would do the same on yours, 100 ton is a big press, what size ram and how much pressure are you running?
Old 11-06-2020, 12:49 PM
Ask Allescense.
The plastic will be quick and easy for remove. It's a general use press, but I'll mainly be using it for forge welding. Having the protective screen is more of a just in case I need it type of thing I won't have it on during forge welding.
Old 11-06-2020, 01:00 PM
The cylinders won't be powered by a hydraulic pump. It's an experimental design. It might fail to produce enough pressure, but in that case I'll convert it to run on a hydraulic pump.
Old 11-06-2020, 11:23 PM
Samcord Samcord is offline
Plastic is easier to remove than other materials? How bout when it gets dirty and scratched up?
