Old 01-29-2021, 03:14 PM
Originally Posted by OleDog View Post
Mine came mounted on an 8"pipe base. I added the pegs tho hang dies on. I have ordered dies as I need them. The square knot is made on the Hossfeld.
OleDogAttachment 159354Attachment 159355Attachment 159356Attachment 159362
Sent from my SM-G970U1 using ShopFloorTalk mobile app
Very impressive square knot. My mind is racking on how you did it.
Did you bend each rod individually around two different dies, or did you tack the two rods together and bend around the die together? I see what looks like a tack weld, but not sure before or after rolling.
Old 01-29-2021, 07:05 PM
OleDog's Avatar
OleDog OleDog is offline
Thanks! I did tack them together. Turned around a mandrel then offset the loops so the ends slid into them. I had a bit of trouble keeping the outside rod from rolling over the top, but a crescent fixed that. The tacks other than the one in the middle usually break because of the different diameters but it's doable.
OleDog
