![]() Sent from my iPhone using ShopFloorTalk mobile app
Hello Brian,
I recently purchased a used Hossfeld Bender #2, and was wondering if you have a digital copy of the Instruction Manual for this bender. Chris P |
Welcome to the pile. What part of CO are you in?
I will have to look. I believe I found them on the hossfeld site, although not sure if it is still up. I will look when I get a chance in a couple days. Sent from my iPhone using ShopFloorTalk
Have you tried this site? https://www.hossfeldbender.com/uploa...log_2018lr.pdf Sent from my iPhone using ShopFloorTalk
Use your imagination and you can bend all kinds of things on your bender.
I made longer pins so i could bend stuff on top of the arms,larger round hoops and i made a product for years that required bending 3/4 square tub,i made 4 90 degree bends in a 14 foot tube,one bend was backwards from the others. Bending on top allowed me to make those bends faster and the reverse bend was easier too. did you get many dies with the bender? |
The PDF Catalog shows you some of the setups. But there is another manual that I believe is only available in print from Hossfeld that is about $30 that shows setups, what pin goes where, etc and is very valuable in learning. If you bought a used bender and several buckets full of puzzle pieces the usage manual is well worth it. I've not seen a digital copy.
I've got 2 of the #2 Benders now and duplicates for most of the angle dies and a few others. So if anyone is near MidMo and in the market let me know.
Stanton, MO in a holler' and the ground is hollow Hobart Handler 210 - HYpertherm 45XP - and a big hammer |
I believe the appropriate metaphor here involves a river of excrement and a Native American water vessel without any means of propulsion. |
Flat stock the hard way is doable with the
51B2 Edge Bend Die uses pins and shims to fit inside the 50B Outbend Master Die for doing angle iron leg out. I recently bought the 51B2 and with shims its was about $250 if I remember? Hossfeld Dies last forever, so buying used is the affordable way. New is good for filling in holes in the collection when you have a paying job because it will save time, but really used is the way to affordably buy. 16B Eye Bolt Bending Dog gets used ALOT bending hooks and such on top. 23B Bending Yoke 26B Sharp Bending Block Pins, longer pins for tope bending, blocks, etc Need a good collection of radius block. I don't have the bulldozer die but will likely get one sometime. I'd just find some 1/2in rebar and start making fire pokers, dinner triangles, some plant stands, etc for your wife and neighbors. That will let you "learn" on the cheap. Leg in Angle Iron is hard to do manually. Also don't get discouraged on the 1st trip through. There is a lot of distortion and stress to deal with. After about 3 trips through things start to smooth out. Just about the time your arm gives out :-)
Mine came mounted on an 8"pipe base. I added the pegs to hang dies on. I have ordered dies as I need them. The square knot is made on the Hossfeld.
OleDog Sent from my SM-G970U1 using ShopFloorTalk mobile app
If you loan someone $20 and never see that person again, it was probably worth it. -- Jack Handey:evil: Do not compute the totality of your poultry population until all the manifestations of incubation have been entirely completed. Nothing says "Poor Workmanship" like wrinkles in your duct tape!! ![]() ![]() Last edited by OleDog; 01-31-2021 at 09:47 AM. |
