#1311
![]() Framing more wall sections. Met with Georgia Power on Tuesday Febuary 9th. So far the plan is to set a pole on my side of the road and then run underground about 250 feet to a pad mount transformer. Out of the transformer about another 40 feet to the meter on the building. Looking at my load calculations I think a 400 amp service will be enough.
Tim Self appointed director of junk, and old vehicles. |
#1312
How things looked when I left this evening.
I need to sit diwn and figure out how much more lumber I need to finish my insulation project on the shop side. I'm holding off on the spray foam because I may need that money for my electrical service.
#1313
Moved some stuff out of my way that was in the shop. Spread some washout into a mud hole in my driveway. Pile has been there a while so needed to use the how to loosen it up so I could get it with the loader bucket.
#1314
With the fluid change did the shuttle shift fix itself ?
#1315
This model has a mechanicly shifted shuttle. Probably would have to split the tractor to fix it.
#1316
Sometimes I just push a broom
#1317
![]() Nothing wrong with keeping a place clean. Sent from my iPhone using Tapatalk |
#1318
![]() Wish that would be all I get if I was to sweep my shop. ![]() Sent from my iPhone using ShopFloorTalk
