#1291
![]() I guess I better decide how I'm going to heat and cool the living space in my garage. I had a local HVAC contractor out and gave me a quote. 6-10k depending on what units I chose. But looks like I need around 3 tons cooling and 35,000 to 40,000 btu of heat. My living space is about 25x40 with a 17 foot cieling. About 300 sqf is a open loft. Two rooms below that are my bathroom and laundry. I'm leaning towards going with a package hvac unit. Propane for heat. Only thing I'm unsure of is can I run my ducts in the space between my ceiling and metal roof? I've got about 8" of space to work with. I'd have 2-3 runs like this. The rest of the supply registers would be in the soffit in the picture. Walls will be standard fiberglass insulation. Ceiling I plan to insulate with R30. When I pulled my permits I put myself down as doing the HVAC.
Tim Self appointed director of junk, and old vehicles. |
#1292
8in is plenty of room to run a duct, but I cant see the R30 and a duct in the same space. Floor registers in the upstairs part may make more sense than compromising the insulation.
#1293
AFCI outlets and breakers are creating problems in my area. Certain brands will trip on circuits with LED lights or displays. This is a known problem but has not been addressed. It will eventually be taken to court. I know a lot of people that have installed them to meet code and then removed them. ( and returned them)
Buy it cheap and stack it deep Klaatu barada nikto |
#1294
Consider a mini split for your living area. Super efficient, runs on a 20 amp, 240v breaker. My unit is a Daikin. Ive measured the output air air temp at 5F outside temp,at 105F. No strip. I am super impressed with it.
They have a HUGE plant in Texas. https://youtu.be/eEcX5fuHp28
#1295
don't forget the return air ducts.
#1296
Two cieling fan boxes mounted, two plain light fixture boxes mounted too. These two will hang down over the eating area.
Ceiling is almost framed in the loft closet.
#1297
For ceiling fans I usually mount a wide (2x8 or wider) piece right behind the box, allows me to add more screws for extra strength. Keeps the flex and vibration down too.
#1298
I thought about doing that but I'm not sure in my situation if it will make any difference. I've kept the boxes mounted to the strips that are close to the roof purlins so I think ill be ok. Vibration on the other hand does concern me. But then again every time a train passes the building resonates. I don't mind though.
#1299
I've been noticing where I've spilled oil on my slab tgat it gets wet when I have situations of high indoor humidity in the building.
I suppose after everything is sealed and the roof spray foamed this should go away?
#1300
Happy Birthday Tim and as Cutter would say be good to yourself.
