Chris The question isn't who is going to let me; it's who is going to stop me. |
Finally, got the rewired lathe motor tested, tonight. I discovered and repaired a missing wire on the centrifugal switch. I verified that B to C was the start coil by attaching a 12 VDC battery to the coil ends, and by hanging a small bolt on a string inside the stator to indicate direction of the run coil vs the suspected start coil (B-C)... they are 90ยบ opposed.
I hooked one end (B) of the start coil to neutral, via a jumper, soldered to the neutral terminal. Then, I dead-ended A, since it is unused in this configuration. Motor started and ran... even turns in the desired direction CCW. Yeah! Now, it's on to tidying up my other major project, almost finished. |
Like the saying goes, "Gotta love it when a plan comes together".
