Old 10-22-2013, 09:26 AM
xterramike xterramike is offline
Default Esseti 501C BEAST of a Carbon Arc gouger!
After unsuccessfully trying to sell my 500amp italian stallion (Esseti 501C wirefeeder/power source), I found a fantastic use for it...as my carbon arc gouger! I had a 12ft plow blade from one of the plow trucks consistently keep snapping an ear off & after yrs of crappy re-welds, the spot was nearly 1" thick. It needed to be taken back down to 1/2" so I could weld it appropriated with the 350P, get good penetration & get it fixed for this winter. I used 5/16" carbon/graphite rods & approx 375 amps to obliterate the gobs of molten metal...it was a blast! I actually found it quite gratifying to see the metal go flying. The angle I was working in wouldn't allow me to get any kind of grinder in there, and it would have taken DAYS to grind, even if I could. Thank you online community for not buying my Esseti...it will be with me until the end! I have several bucket repairs to perform on some excavators & loaders & I can now do them without issue with the carbon air gouger! Can't wait to run some 3/8" rod and hit 500amp! I'll see if I can hit the max on this machine...
Old 10-22-2013, 09:39 AM
Me like air arc.....at this time of year, take leaf blower
around area, to make sure next time you lift your helmet.....
The area isn't on fire.....
Don't ask.
Old 10-22-2013, 09:51 AM
Don't ask.
Haha.. funny, I neglected to mention that this is a fantastic way to locate flammable items in your shop space, even if they're 25+ft away. I was fortunate enough to be working on the plow which itself acts like a self-contained work area (I was working near the bottom of the kickblade, behind the blade)...but before working on said plow blade, I tried out the gouger on a scrap piece of steel, to dial it in & get my form down...this was done on my welding table, and a towel used to clean up a small hydraulic oil spill earlier over the wknd didn't find it's way to the dirty towel bin, instead it was drapped over the forklift drivers seat (forkilift was used to move the blade around my shop, it was 12' after all). Well, that towel caught a blob of molten metal & proceeded to ignite, and kept burning thanks to the hydraulic oil...and a fan that was blowing on it (also used to blow fumes out the shop overhead door)....yep that was bad. I now have a slightly melted forklift seat, have retired another shop towel and probably developed 10 gray hairs when I realized something was on fire behind me...good times!
Old 10-22-2013, 10:25 AM
Huge sparks, very loud noise, occasional fires and fast metal removal!!! A great way to spend an hour!!!
Old 10-22-2013, 01:50 PM
FabberMcGee FabberMcGee is offline
Yep, lots of fun and everyone within ear shot knows you're using your big boy tools.
"The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it."
“The thing about quotes on the internet is you cannot confirm their validity” Abraham Lincoln
Old 10-22-2013, 01:58 PM
I always wondered what it would be like to run air arc off a detroit
powered lincoln portable....with the muffler off.....
