Rest In Peace Cutter
  #111
Old 12-17-2018, 10:02 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
I have the north roof stripped to the rafters and most all the demo work done on it. There is a little more demo to do, than to clean up the attic floor and replace the jack studs under the rafters. One rafter needed replacement, I have it laid out and ready to cut.
The plan for today is, replace the jack studs, remove the bowing in three of the rafters with the new studs and start putting the purlins on.
After it got too dark to work on the roof yesterday, I started cleaning up the old shingles and wood from the roof. The wood I burnt, and the shingles I am stockpiling until I can get a dumpster in to take it to the demolition landfill.
Well it is off to get started with the rebuild.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
  #112
Old 12-17-2018, 10:50 AM
Lu47Dan's Avatar
Forgot to mention, I need to buy more lumber, the way my Dad built the original flat roof included a 1-1/2" overhang of the 1 X 12 pine decking boards as a drip edge. Now fifty some years later, it is a problem, the easy way would be trim them back to the facia board and be done with it but then I would have to recut all the rafters and remove and trim the wood on the end walls. Too much farting around....
So, since the facia board is weathered to the point of needing replaced. I will buy two 2 X 8's and two new 1 X 8's to bring it out even with the decking boards. Simple fix , that will cure the problem of securing the gutter hangers to the building.
I am going to replace the old gutters with new when I finish the roofing up.
The gutters that are on the shop are salvaged from several sources over the years.
Dan.
Hobart 175 Mig
Craftsman O/A set
  #113
Old 12-17-2018, 04:31 PM
Lu47Dan's Avatar
Well, it is ready for the purlins now.
Photos attached.
Replaced the bad rafter and installed new jack studs. I need to pick up some shorter screws tomorrow, the ones I used were 3-1/2" long. They really stick out of the stud, I caught my leg on one of them already
I am thinking of buying 10lbs of 2-1/2" construction screws, cheaper to buy 10lbs than 5lbs. Might buy a 1 or 2lb. box instead, if the price works out.
Well off to make dinner.
Dan.
ID:	148489   Click image for larger version
Hobart 175 Mig
Craftsman O/A set
  #114
Old 12-17-2018, 04:51 PM
Lots of work!!!!!!!!!!! Are you a one man show?
  #115
Old 12-17-2018, 05:24 PM
Lu47Dan's Avatar
Yep, during the week, and on weekends if my brother is working at his buddies shop.
Once I am ready to put the steel roofing on, my brother and a few friends are going to take a vacation day to get that part done.
Dan.
Hobart 175 Mig
Craftsman O/A set
  #116
Old 12-22-2018, 05:13 PM
Lu47Dan's Avatar
Update
Well since my last post to this thread, I have finished up installing the purlins, the west end facia board, all of the north eave facia board and I am ready to install the east facia board, the gutter apron and start sheeting the roof.
But during that time I lost a day to the weather (rain) the flu (two days), and help not showing one afternoon. Next time he needs something welded, he will find out what it costs at some of the local shops.
Also during this time, I cleaned up the old wood and shingles from the roof. I burnt the wood, stockpiled the shingles and have burnt the burnable junk from the attic. So half the mess is cleaned up. Also had to tarp the roof as we had rain coming on Thursday evening.
So today, I managed to get the last piece of eave facia cut to length and installed.
Tomorrow I hope to get the purlins cut to length. The eastern facia board cut and installed, then start installing the steel.
We will see.
Dan.
Hobart 175 Mig
Craftsman O/A set
  #117
Old 12-25-2018, 11:15 AM
Lu47Dan's Avatar
Well yesterday, I finished up the cutting jig.
Took a shipping pallet apart and burnt the last of the wood and burnables from the roof.
Do not know if I will do anything on it today or not.
Dan.
Hobart 175 Mig
Craftsman O/A set
  #118
Old 12-27-2018, 07:20 PM
Lu47Dan's Avatar
Well, yesterday was the day. The weather finally cooperated with putting the roof sheeting on.
I got home from work and decided to work on the roof. I laid out the length and cut the tails of the purlins. Then I cut the facia board and installed it
Then I was ready to start installing the steel roofing panels, I even had help.
My brother got the afternoon off and my neighbor was off, he was using up his final days of vacation for this year.
We installed five panels before it got too dark to continue. At this point it is about 90% dried in.
I finished the rake trim and installed the temporary ridge cap today. So it is on to the wait for good weather to rebuild the south side.
Dan.
Hobart 175 Mig
Craftsman O/A set
  #119
Old 12-27-2018, 07:31 PM
Have ya on top of the hill yet?
  #120
Old 12-28-2018, 04:19 AM
Lu47Dan's Avatar
Thanks, Ted.
Funny, I do live on a hilltop here.
Dan.
Hobart 175 Mig
Craftsman O/A set
