Old 12-06-2007, 11:19 AM
Default Various pictures from the shop
Since I had the camera in the shop to get a picutre of my compressor (See my compressor thread in Eqiupment section) I took a few pictures of some other things while I was there.
The first two are of one of my shop squares. I drilled and tapped it for three short 3/8" bolts. No matter what side it is on I can always pick it up off the table, it also puts the square higher than the rounded corner of a piece of square tubing.
The second is my version of a "Quick Fire Pit" (from a recent thread about a water heater tank fire pit). This one is not near as quick, far more expensive (half sheet of 1/4"), but much more comfortable to sit around. It was built for a customer, and I now need to retrofit it for a propane burner.
The last one is a mod I made to one of the chinese rollers so I can roll arches into 1" tubing. I have rolled an arch as tight as 24" with no problem out of .065 wall tubing, and could likley go even smaller but I have not tried.
Name:	Shop Equip 003.jpg
ID:	25567   Click image for larger version
Name:	Shop Equip 006.jpg
ID:	25568   Click image for larger version
Name:	Shop Equip 001.jpg
ID:	25569   Click image for larger version
Name:	Shop Equip 007.jpg
Old 12-06-2007, 11:22 AM
Here are a couple of a screen door I am going to install today. The leaves are all hand made, the color was done on the leaves and tree trunk by various methods of rusting, then clear coating. I then went back and tinted some clear coat with green red and yellow and added a wee bit of color to the leaves.
Name:	Shop Equip 009.jpg
ID:	25571   Click image for larger version
Name:	Shop Equip 010.jpg
ID:	25572   Click image for larger version
Name:	Shop Equip 011.jpg
Old 12-06-2007, 11:31 AM
I love the screen. Real custom work.
Old 12-06-2007, 11:32 AM
I like that one, Walker. It's downright startling.
What did you use to make the trunk?
Old 12-06-2007, 11:42 AM
Thumbs up
Nice work on that door Walker. My only question is would be, is it to be installed on your house, or a customer?
Excellant work in fact.
Old 12-06-2007, 11:59 AM
Photomask's Avatar
Photomask Photomask is offline
Big Stone
The screen door is most impressive. Metalwork and common application as art almost always leaves me smiling.
I would like to see some better pictures of the fire pit, the base and such. I suspect there is some good looking work hidden under there. And I haven't started on mine yet....
Old 12-06-2007, 12:37 PM
Cutter, the trunk is just 10 ga cold rolled steel butted up to the 1x2 door frame. I welded beads on it for the texture, ran it a bit cold with higher wire speed, then sanded the tops off. Afterwards I textured the whole thing with a flap disk in various directions.
Lwhiway, it is going up on a customers house. I had made a kinetic sculpture for her out of leaves a year ago and she wanted to continue the theme on the door.
Photo, I'll see what I can do in the next day or so for some more pictures. The top is a single sheet of 1/4" that I cut pie wedges out of, heated the line to bend it and bent them up to meet. The base and foot rail is 1 1/2" pipe with 1/4 x 4" flat bar to support it. The foot rail gets warm enough to keep your feet comfortable, but not too hot to burn your shoes.
Old 12-06-2007, 06:47 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Walker , I do not say this very often but Beautiful job on the screen door . Sometimes it has to be more than "good job" . Dan
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 12-06-2007, 07:17 PM
randydupree's Avatar
Why, Hell Yes!
wow! thats screen door is awesome!
and t if thats a fire pit its too nice to use!
Randy
