Old 11-21-2018, 10:16 AM
alchemist's Avatar
I had to laugh at this.
Years ago, I had a friend that owned a weld shop, just him & his son.
When he would drill something on the big 'ole drillpress, he would
get out a prick punch made from IIRC 3/4" hex rod.
Wail away with a 5lb several times to make the marks big.....really big.
I said "Why did you stop ? A few more whacks, and you wouldn't
need the drill press".....
That's so the hole would be countersunk already when the hole is drilled.
Old 11-22-2018, 11:07 AM
I had to chuckle, Chris. When I was a kid, still at home, (Wasn't 16 yet) I made a center punch from a valve. They work well.
I was about 19 when I made mine.
Woodrow Wilson
Old 11-22-2018, 11:09 AM
Originally Posted by alchemist View Post
I'm with you on that. I don't do any grinding or wood on my lathe.
I don't mind wood or plastic. Messy, but it don't damage the ways.
Woodrow Wilson
Old 11-22-2018, 11:10 AM
I am sure that they would, I think I should leave the valve
head on, the way I swing at things now
I have decided I need to up my cheaters from 1 1/2 to 2 1/2.
Woodrow Wilson
Old 11-22-2018, 11:26 AM
Nice punches!
Just don't use sodium filled valves I'm sure you are aware of what can happen...
If not check out 1:45 to 1:60 of this video
https://www.bing.com/videos/search?q...EF10&FORM=VIRE
just a heads up for those who don't know if ya have one made into a punch or cutting on a band saw with cooling fluid or some how crack fractures while punching and moisture or water is introduced unknowingly could be disastrous
Old 11-22-2018, 06:20 PM
clive's Avatar
clive clive is offline
I have never heard of sodium filled valves, what is the purpose?
It's So Easy
Old 11-22-2018, 06:55 PM
Heat dissipation. Keeps the vales from getting too hot.
Woodrow Wilson
Old 11-22-2018, 07:05 PM
yep helps keep them cooler and can be found in all types of automotive and diesel heads used usually in the exhaust valve but in some applications you can find them in both intake and exhaust.
Old 11-22-2018, 10:06 PM
I keep an assortment of valves around to use as light duty seal drivers. Never thought about using them for center punches.
Old 11-22-2018, 10:18 PM
All the ones I made were solid.
Woodrow Wilson
