Rest In Peace Cutter
Old 10-15-2018, 11:03 AM
Norm W's Avatar
Norm W Norm W is offline
Well, now you know what you will look like in 30 years.
Old 10-21-2018, 08:16 PM
weldor2005's Avatar
Perpetuus Discipulus de Vita
Time for the grates. Using 1" x 1/8" angle.
I prefer to do my miters out of one piece of stock if possible, so this is my cut.
Bend as needed. It all changes when you square it up anyways. I like to go corner to corner when doing so.
Test fitting
Holding it all down and in place to weld the grate into it's frame.
This is a rare instance I use the table spacings the way I envisioned when I made it. 5/8" T-nuts.
My first rack needed persuading to get flat, it was high on opposite corners for some reason when making the frame. I resolved that before putting the expanded metal in though. The second one was nice and flat.
David
My YouTube Channel
Old 10-21-2018, 08:20 PM
weldor2005's Avatar
The two main racks are in it. This is to summarize the last post really with the picture limit and all.
I plan on more racks, but fighting myself about placement at the moment.
David
My YouTube Channel
Old 10-21-2018, 08:26 PM
weldor2005's Avatar
Today's mission was to get this thing supporting itself. Leg design started with sketching, moved on to math. I need to put a new calculator on this phone just to get trig functions. Either way I settled on a 70* angle for the legs.
Got the speed square angles working using a piece of angle.
No picture, but since I don't have a pipe wrap, I used some worthless paper manual and traced using that.
David
My YouTube Channel
Old 10-21-2018, 08:33 PM
weldor2005's Avatar
My initial thought was to slice a notch in the pipe half way and sit on the end like this. Then the smoker gods said not to do that. Then SWMBO said it looked stupid. So I settled on a more modern look.
Waste not though, what I cut off was used in the other side.
David
My YouTube Channel
Old 10-21-2018, 09:00 PM
SmokinDodge's Avatar
The wife has solid taste when it comes to smoker mods.
Of course I would have never done it that way and it will never work.
Old 10-21-2018, 09:24 PM
Yes the wife was right!!
Old 10-21-2018, 09:59 PM
I see two little wheels up front and bigger in rear as in a traction engine .
Old 10-21-2018, 10:05 PM
jdpflyer's Avatar
jdpflyer jdpflyer is offline
SWMBO shouldn’t hold back and tell you what she really thinks!
Jimmy
______________________________________________
The quickest way to become a millionaire in aviation is to start with two million.
Old 10-21-2018, 10:44 PM
JBFab JBFab is offline
The missus has good taste! I like it!
Ok, I'm dying to know - you built the racks flat, how did they sit on the angles we put in??
Sent from my XT1650 using ShopFloorTalk mobile app
