Old 03-28-2018, 09:33 PM
Scrapper Greg's Avatar
Kent, looks like a 220cid engine if its original. But they list 2. A BD220 and an SD220. Not sure what the difference is but they do take different rings. Stuff is available from Rockauto still. It is a neat thing you did with the knuckle boom.
MAGA
Old 03-29-2018, 09:36 AM
Kent_323is's Avatar
Kent_323is Kent_323is is offline
Thanks Greg.
I'll be heading to the shop this weekend, so I'll see if I can find the engine tag to confirm the engine type. At least then I can research some future options... rebuild or swap.
I have experience doing engine rebuilds, so that's a more likely route... just need the time and priority over other projects.
Kent
My shop and projects: www.kustomsbykent.com
Old 03-29-2018, 01:07 PM
Shopmonkey's Avatar
Originally Posted by Scrapper Greg View Post
Kent, looks like a 220cid engine if its original. But they list 2. A BD220 and an SD220. [|B]Not sure what the difference is but they do take different rings. Stuff is available from Rockauto still. It is a neat thing you did with the knuckle boom.
I think it would be a BD 220. The SD's came out in the later '50s. The one you have in the "51 has babbited bearings so you don't want to overspeed them. You've got a good old truck, there. Worth overhauling and using. Or, for sits and shiggles, measure some stuff and see if you can't get a 4-cyl diesel to squeeze in there. Perkins would be a good choice or a 4BT Cummins
RIP Cutter
Old 03-29-2018, 08:22 PM
That's what I believe too, but Rockauto listed the SD too. I'd almost pull the head and pan, do a quick check of the bores and throw a set of rings in it if the bores passed muster.
MAGA
Old 04-09-2018, 03:03 AM
DeepSeaDynamo's Avatar
DeepSeaDynamo DeepSeaDynamo is offline
Originally Posted by camdigger View Post
Having worked with cranes and hoisting equipment most of my career, I can say with some confidence that speed is not necessarily a good thing for crane operation.... There are many examples.....
Most cases this is true, but nearly all my crane experience is on boats and there were times the crane wouldn't move fast enough.
