  #31
Old 10-14-2016, 12:10 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
Nice job, Cav but, you're gonna' have a hell of a draft under that side door.
Dave
  #32
Old 10-14-2016, 08:31 AM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
Dave
That leaves room to install the pet door.
  #33
Old 10-14-2016, 11:27 AM
Dave
That's a Dutch door for short people.
  #34
Old 10-14-2016, 06:41 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Back section is rolled back. Have to fight everything back into square and plumb tomorrow then onto building!
  #35
Old 10-14-2016, 06:43 PM
rock6.3's Avatar
rock6.3 rock6.3 is offline
How is the old wood structure tied to the new block wall?
Young enough to be dangerous, old enough to know better (most of the time anyway)
  #36
Old 10-14-2016, 07:02 PM
Cavalry's Avatar
Below Wholesale
In the front I filled the cores and will drill the sill then redhead. The main shop was built by a competent contractor where as the addition I slid back was built by the previous homeowner. I have found time and time again that he never completed his Time Life carpentry series books as everything he touched was wrong on multiple levels, the addition was no exception. Worst part other than not being square, was the sill was KD not treated. It was not rotten yet, but its only 10 years old. I redheaded a treated sill down then slid it back on that, same concept, just a double sill.
  #37
Old 10-14-2016, 07:07 PM
rock6.3's Avatar
Thank you. I wondered because here we have to have j-bolts poured into the concrete that then bolt down the sill with the required square washer. (damn bureaucratic building codes)
  #38
Old 10-14-2016, 07:42 PM
Cavalry's Avatar
Below Wholesale
Yes, J bolts are required here, no square washer though. There was no practical way to do them so redheads it is. The redheads have something like 10Klb pullout rating, the mortar joint or wood sill will fail well before that.
  #39
Old 10-25-2016, 04:12 AM
Cavalry's Avatar
Below Wholesale
Small updates, Man door is in and the hole patched up. I cobbled up the right door with parts from both so it can keep the weather out. It will not move, just a filler until I get my new door built which will be in the spring. My left door is mostly built and framed in, just need to set the header and install.
Trusses come today and I have next week off. Hopefully I will get a decent week to work!
  #40
Old 10-26-2016, 08:12 PM
Well the process may have been a little unconventional. But it looks like it's going to be way more bedda to work in.
