Old 04-16-2019, 03:17 PM
Weight only comes in three varieties " I can lift it " , "the machine can lift it "
and "I do not have anything that will lift it"
Once an object leaves the first category the actual weight is just a number.
Old 04-16-2019, 09:11 PM
cramd's Avatar
cramd cramd is offline
Drivin' Fool
Right now, I can think of another variety related to your first one: I use to could lift it (to paraphrase Jeff Foxworthy) .
Miller Thunderbolt XL AC/DC
Hobart Handler 190
Old 04-28-2019, 04:24 PM
Finally got the plates back, I goter done. I do these blades in three pieces, more welding but easier to fit. Used .045 duel shield wire. I am under strict orders since I pined myself under a hopper that SWMBO must be present whenever I roll something heavy but I don't mind because she helps running the hoists and moving the chains.
1 test fit
2 had to bring out the beast for the bevel
3 backup strips
4 Used my Harbor freight com a long for the outer plates
5 bottom weld (Sure is nice having two hoists)
ID:	150555   Click image for larger version
ID:	150556   Click image for larger version
ID:	150557   Click image for larger version
ID:	150558   Click image for larger version
Old 04-28-2019, 04:27 PM
1 top weld
2 front welds
3 end weld, trimmed later
4&5 done
ID:	150560   Click image for larger version
ID:	150561   Click image for larger version
ID:	150562   Click image for larger version
ID:	150563   Click image for larger version
Old 04-28-2019, 05:35 PM
Vernon's Avatar
Vernon Vernon is offline
1 test fit
3 backup strips
I used a lot of Dual Shield Essb brand. Some days would burn 80 lbs of 1/16" off in 8 hrs. looking good.
Due to the lack of effort today Tomorrow has been canceled...................
