Old 10-19-2009, 10:53 PM
Griffino Griffino is offline
Default De-stressing aluminum
I'm looking to de-stress some sheet aluminum, it's the cheap stuff you buy from Home Depot; the flashing material stock. I need to hold it into shape and keep it there, basically flat. It come in a roll that's quite tight and I don't have the means to unroll it flat otherwise. do you have any suggestions? I have a home made oven that is large enough but might top out at about 700f. (only tested to 500f in the past)
Old 10-20-2009, 01:38 AM
Gadgeteer's Avatar
May I suggest that you draw it over a section of PVC pipe (4" diameter?) to induce flatness.
Old 10-20-2009, 02:20 AM
billtr96sn's Avatar
billtr96sn billtr96sn is offline
To anneal aluminium, cover it in hand soap and heat until the hand soap turns black, then stop.
Co-incidentally the temp soap turns blsck is the same temp for annealing aluminium.
Little Bike forum www.billsbikechat.co.uk
Old 10-20-2009, 02:48 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
Can't help you with the flashing but, I bought a roll of the painted coil stock, used for capping windows and such and it unrolls flat. Just something for future reference. By the way, welcome aboard.
Dave
Old 10-20-2009, 12:59 PM
Thank you very much guys! Great responses. I was considering each of the 3 ideas you proposed. 1: Mechanically unrolling; i need this stuff really flat also I'll need to de-stress after breaking into the final shape. 2: soap, interesting idea.... 3: I'd love to find some of that stuff, I'm in Alaska and we are kinda behind everyone in what is available, but still looking...
Thanks agian!
Old 10-20-2009, 11:37 PM
Paychk's Avatar
Paychk Paychk is offline
Project Phoenix
What part of Alaska; Anchorage used to have Home Depot and Eagle Hardware (I think Lowes bought them)
Ory-gun Boy!
