  #41
Old 08-28-2009, 11:55 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Greg , first
Welcome to SFT
Second , I have never personally used shark bite connectors , so I have no real world experience to draw on .
Sweating pipe can be done with a propane torch and a minor investment in tools . The tools being a Imp (close quarters) cutter , a cutter that goes to 1-1/8" , a roll of plumbers cloth ( sand paper ) and a few fittings to practice with .
I prefer sweating copper because I am a plumber/pipefitter in building trades .
Dan
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
  #42
Old 08-28-2009, 12:00 PM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
Pvc...
  #43
Old 08-28-2009, 12:04 PM
I had wondered if Sharkbites would work for air lines.
I can just barely scrape up enough courage to use them on exposed water lines but I've got a few that have been in place for a couple of years now.
I've only seen one leak so far; it was installed on a really cruddy 1/2" copper line that had a little dimple in it and even that was a slow leak. All I had to do there was trim about 1/2" off to remove the dimple.
But there's a lot of difference (in my imagination ) between a 30-40 psi water line & a 150 psi air line.
So I dunno.
  #44
Old 08-28-2009, 12:42 PM
rmack898's Avatar
rmack898 rmack898 is offline
That HURT!
I've never seen http://www.plumbingsupply.com/shark-bite-fittings.html these before but at over $6 for a 1/2" coupling, I can buy alot of sweat fittings and maybe even o roll of solder.
I've got Moe air
Mac
  #45
Old 08-28-2009, 12:44 PM
stonebriar126's Avatar
stonebriar126 stonebriar126 is offline
I am waiting for the sweating joints for dummy's (not burning your shop down) tips. Good thread.
Rick
  #46
Old 08-28-2009, 01:03 PM
moe1942's Avatar
Voice of Experience
I've got Moe air
Hell Mac, we've had experts try to snuff us so I ain't skeered of no PVC.. Been using it for close to twenty years with 175# air..
  #47
Old 08-29-2009, 12:39 PM
kbs2244 kbs2244 is offline
I have a total of 6 SharkBites above my ceiling in my FLA place.
Each end of 3 patches.
(Copper pipes don’t like RO water.)
Local plumbing house said not to worry.
He sells a lot of them and they don’t come back.
But that is water, not air.
  #48
Old 08-29-2009, 01:45 PM
I know, I know ... mine says the same thing.
But their reassurances don't pay the freight if the ship hits the sand.
I think the thing about Sharkbites that makes me nervous is they're just too stinking easy to use. It's the equivalent of a framing nail you could drive with your index finger, or welding half inch plate with a propane torch.
They give the appearance of defying natural law.
  #49
Old 08-29-2009, 09:55 PM
akabull's Avatar
akabull akabull is offline
Maine-iac
I have installed a few shark bite connectors, 1/2" in our server room for the drain on the humidifier (been there 2 yrs w/ no issues) because i was leery of using a torch around all those high dollar puters. and the other was some 1" pex to run soft water to out marley cooling tower. I had to go over and around about 30-40 different sized piped and the pex was the only way to go. Sharkbite connectors are the same thing as push-lok or legirs poly tube fittings that have been in use for a long time. I work in the printing industry where compressed air is our bread and butter, and all of the poly air lines are connected to solenoid valves, cylinders, etc with push-loks (aka sharkbytes). If it weren't for push-loks life would suck. The typical failures I see are fittings installed in harsh enviroments - where heat, chemicals, or oils do the damage. Not the fitting itself failing.
Chris in Maine
  #50
Old 08-30-2009, 12:10 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
For those of you who watch This Old House, you know the plummer, Rich Trethewy. I've seen him use the shark bite fittings and it's the same story, great for areas that are too risky for a torch.
Has anyone had experience with the crimp-type copper fittings that he's demonstrated on other episodes? The fittings must be a lot cheaper than shark bites but, they probably, make up for it with the special crimper that you need to buy.
Again, something that would be great, in risky to solder areas.
Dave
