Old 10-24-2007, 06:13 AM
clive's Avatar
clive clive is offline
Default Tempering chisel steel
I had an apprentice make, harden and temper a chisel today. He did what I have always done, after he had forged it he dressed it up on the grinder and then heated the end red, plunged 1/2 of it in water and then cleaned it with emery quickly and waited till it turned straw and plunged it in the water.
He had done a beautiful job of shaping it but when I looked at it there was a crack through, which subsequently broke off when I smacked it with a hammer.
I had done several chisels earlier by this method without any problem. The only thing I can think of is that when he was forging he didn't have it hot enough and kept hammering when he should have had it back in the heat. Plus the chisel could still have been a bit red when he plunged it a second time Any suggestions?
Clive
Old 10-24-2007, 06:57 AM
OZWELDER's Avatar
OZWELDER OZWELDER is offline
G'day Clive,
The steel is probably an oil quench rather than a water quench.
Ozwelder
Old 10-24-2007, 02:09 PM
Brian C.'s Avatar
Brian C. Brian C. is offline
Director of Security
Originally Posted by OZWELDER View Post
G'day Clive,
Ozwelder
My thoughts exactly, but then again I am no metallurgist.
Millermatic 211
Harris oxy/act.
2 propane forges
147 lb. Peter Wright anvil
Old 10-24-2007, 03:54 PM
EMF EMF is offline
I learned that it was "high red', then oil quench when it got back to "wheatstraw"; no water involved; worked real well for the gad end and chisel end of mining picks. The blacksmith who was our teacher/mentor could stick a pick in the flank of an anvil and it would stay; we made and tested our own slag hammers the same way.
EMF - Messin' with stuff for some 60 years, or so.
Old 10-24-2007, 06:02 PM
clive's Avatar
Yes, I am leaning towards the oil quench too, I will have to experiment with it over the next few days.
Thanks
Clive
Old 10-24-2007, 06:59 PM
precisionworks's Avatar
Water quench is pretty violent, some steels are made to withstand the shock (W1 for instance), others need the more gentle oil quench. Some steels, like A2, are "quenched" in still air.
Oil is probably the safest medium.
PM's are disabled
Old 10-25-2007, 12:26 AM
ace4059 ace4059 is offline
Tender Member
I have a question: It maybe stupid but what oil do you guys use.
The reason I ask is because it seems to me, some oils would burst into flames if you placed red hot metal in them.
-Ryan
Lincoln Pt 225
Lincoln PM 215
Lincoln Buzz Box
Hypertherm 600
HH125 EZ
MM 350P
TB 302
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an unlicensed pharmacist.
Old 10-25-2007, 01:34 AM
Brian C.'s Avatar
Many oils are suitable. Never use old motor oil Use in a container of sufficient volume and has a lid you can drop quickly to smother any flare ups
Millermatic 211
Harris oxy/act.
2 propane forges
Old 10-25-2007, 01:56 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
When I first started in the tool & die shop, they had a 5 gallon can full of refridgeration oil that they used for quenching. I'm sure the only reason was because we manufactured water coolers (called bubblers or drinking fountains elsewhere), and we had the stuff in abundance. It worked but, there was always a little flame as the part was plunged into the oil. Later on, we got a production engineer in that, had a very good chemical background and suggested quenching oil would be much safer. There was no flame with this stuff. We only heat treated little, "hurry-up jobs" in house and quenched the parts down cool enough to handle. Then, polished them up and reheated them to show the oxide colors and quenched them again. I'm sorry, but, I don't know who made the stuff. Maybe, Shade Tree can help here. The guy who ran the shop before I took over loved his 0-1 because he could heat treat a lot of his stuff in house. I hated the stuff because it warped so much that you had to leave a lot of excess material on for surface grinding to final size. We switched to A-2 after he retired. Beautiful stuff. We also used D-2 if the die would run a lot of stainless steel. Nasty stuff to grind. One pass across and back and the wheel needed dressing. What a pain!
Dave
Old 10-25-2007, 04:06 AM
clive's Avatar
OK, I went back to the stores and asked what steel they got, they said "we couldn't get what you asked for so we got something else" my fault for assuming they would let me know of any problems. So I went to the supplier and it is AISI S1 which anneals at 760oC, hardens 860-900oC in "oil or hot bath 180-220oC" (quote). According to their chart it is tempered at 550oC for 2 hours.We have an electric oven which goes up to 1200oC so that is that problem solved I hope. I will try it in oil at 180oC next week.
Thanks for your replies they are appreciated.
Clive
