Old 12-30-2018, 11:59 PM
Default Mill Mounting Plate
Started making a mounting plate for the mill today. It is a 1/2" plate and will have several tapped holes with 3/8-16. Also have four 1/2-13 holes to bolt to the table T nuts. Today I ran a 2" facing cutter to get a flat smooth surface on the plate. Came our real well. The hole layout will be tomorrow.
Old 12-31-2018, 09:52 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Chris, dye the surface or use a sharpie to lay out the hole pattern, this will give you a visual reference to the hole locations while you are moving location on the plate.
Add a secondary pattern of 1/4" - 20 tapped holes.
Most work I have done on a plate is light machining, so it is handy to have smaller clamping accessories at times.
Once you lay out the 3/8" pattern, drill it before laying out the smaller 1/4" pattern or use a different color sharpie to mark them. Drilling many holes of two seperate sizes can and does get confusing.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 12-31-2018, 11:10 AM
Once you lay out the 3/8" pattern, drill it before laying out the smaller 1/4" pattern or use a different color sharpie to mark them. Drilling many holes of two separate sizes can and does get confusing.
Dan.
Already put on Dykem on the plate. I will only have four 1/2" holes to mount to the table. Will use flat allen head 1/2" screws to attach to the table 1/2" T nuts. I do need to get a set of 3/8" studs and clamps. I could get some 3/8" T nuts, then I would not need the 1/2" holes. Decisions, decisions, decisions.
Old 12-31-2018, 02:16 PM
Smaller clamps can also be made. I have some as small as 5mm.
With smaller clamping setups, the height should be kept to a minimum, so socket head cap screws or hex head bolts can often be used instead of studs.
Old 12-31-2018, 03:08 PM
Cap screws! Another good idea. Thanks.
Old 12-31-2018, 05:17 PM
Just make sure to use decent washers. I used to have sources for heavy (williams was what we called them) washers that worked really well for clamping applications.
Old 12-31-2018, 05:24 PM
I have lots of good washers.
Old 01-01-2019, 09:28 PM
Too cold for shop work yesterday. Did get the four 1/2" holes laid out and drilled today. I will get the countersinks done tomorrow. Probably lay out the 3/8" tapped holes too.
Old 01-02-2019, 07:26 AM
Well Chris... I cant wait to see the final product, well, I mean I have to wait but I am, looking forward to seeing it once you finish the mounting plate
Old 01-02-2019, 12:09 PM
I use a standard pitch of 2.5" or a multiple of 2.5" for all my fixtures in my shop. The 2.5" is derived from the T slot spacing on my milling machine. This allows me to use fixtures on all four of my fabricating tables which also have the same pitch and thread.
Shit began hitting the fan in the 1950's https://m.youtube.com/watch?v=nRnNDkHb0MU
