Old 11-13-2006, 01:38 PM
jksweld's Avatar
jksweld jksweld is offline
Default has anyone used these power feeds
found these on ebay and was thinking of making a line bore rig and using this to feed the bar and a 120v motor to turn the bar 135 lbs power feed
150 lbs power feed
what do you all think
Thanks James
SAGO MINE TRAGEDY
WE WILL NEVER FORGET
1-2-06
Old 11-13-2006, 06:41 PM
lars66's Avatar
lars66 lars66 is offline
I wonder if the torque rating holds up at the low speed end?
Old 11-13-2006, 07:15 PM
precisionworks's Avatar
Bridgeport power feeds have really limited torque. When the ad states 135 lbs or 150 lbs, these are not American lbs. Chinese probably, much like Chinese horsepower ... which must come from tiny horses that aren't well fed
The power feed has no more torque than you can apply by hand, maybe 13.5 to 15 foot pounds. It sounds like you need more. A gearmotor with VFD control is probably the easiest approach.
Always a bunch on eBay for a giveaway prices: http://tinyurl.com/yk4bmm
The three-phase AC models can be VFD driven. The 90 volt DC models use a DC motor controller. Both of those can also be found on eBay, or at retail supply houses.
PM's are disabled
Old 11-13-2006, 08:39 PM
Scotts Scotts is offline
It looks like the one we had on a mill at a place I used to work for. If it is it won't survive a drop test. In one of the pictures on the ebay site it shows some pictures of parts in a sack. That big gear is plastic it was the weak link in ours. I do see that there is some type of overload on it.
I will go with precisionworks on his assesment.
Old 11-13-2006, 09:04 PM
Jeff's Avatar
Jeff Jeff is offline
Big Iron
James,
Last year we bored a 14 1/2" bore in a dragline and use a 1 hp motor with a dodge shaft mount speed reducer for a drive,and it worked great.
Jeff
Old 11-14-2006, 02:50 AM
jksweld's Avatar
first off thanks for the help, but I still don't understand a few things. Pic #1 is what Iam using for a "pattern". I have a 1/4 horse gearmotor that is reversable that I can use as the feed drive or the bar drive (if it will work as one or the other). the "pattern" in pic 1 is about 9amps and 35ft lbs of torque and the feed drive is 200 inch lbs of torque.If I use my motor for the bar drive I think I can controll the speed by one of these and maybe use this for the feed drive
and control the feed rate the same way as the bar speed
Ok heres a drawing I drew up, not as good as digr's but I think it will help
thanks James
ID:	17413   Click image for larger version
SAGO MINE TRAGEDY
1-2-06
Old 11-14-2006, 03:40 AM
jksweld's Avatar
how would this do for a feed drive
1/15hp
250 inch lbs torque
cant get the link button to work here it is
http://cgi.ebay.com/DAYTON-2Z797D-AC...QQcmdZViewItem
James
SAGO MINE TRAGEDY
1-2-06
Old 11-14-2006, 12:23 PM
lars66's Avatar
1/15hp
250 inch lbs torque
James
I think variable speed would be just a important on the feed as on the bar rpm.
Old 11-14-2006, 09:30 PM
Jeff's Avatar
Big Iron
I would just worry about the drive for the bar and use a hand feed.
Jeff
Old 11-14-2006, 09:52 PM
stock z/28 stock z/28 is offline
Hi,
For what its worth I have a couple of these power feeds on mill tables and they seem to work well
Jeff
