Old 12-08-2023, 03:52 PM
JP_in_STL JP_in_STL is offline
Default Crimp vs Cope for 1in Sch40 Pipe
So I want to make some Firewood Racks. I have LOTS of 1in Sch40 Pipe Drops that are 5-6ft long. I want to make them look decent, but I don't want to take the time with a ChopSaw or HoleSaw in a JointJigger to properly cope the pipes. All the joints will be a T or 90 intersection. I'm thinking crimping the end of the pipe into an oval would look nice enough and be quicker to fab.
I know I can take a 3lb drilling hammer and wail on them enough to flatten them a bit. But I'm looking for a quicker and repeatable option. How much force would be required? I've got a 3Ton Arbor Press? I've also got a Hossfeld Bender with a large die collection.
I'm thinking the Hossfeld would do it, I'm just having trouble visualizing the setup? I've got the Angle Iron Leg In/Out Dies, BullDozer, Bending Yoke, but no hydraulics. I'd also like to do them cold if possible?
Also any inexpensive ornamental pipe cap ideas?
Stanton, MO in a holler' and the ground is hollow
Hobart Handler 210 - HYpertherm 45XP - and a big hammer
Old 12-08-2023, 04:11 PM
I'd print a pipe wrap and cope them with an angle grinder with a zip disc/cut off wheel. Use the pipe seam to line your wraps up at each end.
After you get the first cut figured out you can fly through them and with the ends coped the set up for welding will be much easier.
Old 12-08-2023, 05:24 PM
boilerman's Avatar
SFT Brewmaster
^^^^^^^^ I second that, 2 quick angle cuts and it is coped.
Old 12-08-2023, 06:16 PM
And...way stronger than crimped
Old 12-08-2023, 07:34 PM
If you have a chop saw just cut the pipe at a 45 as shown and with a little work with a hammer you will have it.
Old 12-08-2023, 07:40 PM
LKeithR LKeithR is online now
Actually, for size on size coping I think the angle works out closer to 35 degrees. I haven't done it for quite a while but I know that when making loads of pipe rails you can make two cuts and, with maybe a touch from a grinder, get it close enough that all the gaps fill easily. Do a couple test cuts till you get it close...
Old 12-08-2023, 10:25 PM
arizonian arizonian is online now
Chop saw is your fastest option, followed by a zip wheel. Keith is right, about a 35° cut about one third of the pipe, flip it and make the second cut.
For a rake or slope joint, a steeper angle on one side half way across, then zip the point off at the angle of the rake.
ID:	169528   Click image for larger version
ID:	169529   Click image for larger version
ID:	169530   Click image for larger version
ID:	169531   Click image for larger version
Old 12-08-2023, 10:42 PM
I have no real tips once an "Old Hand" clued me in I've just freehanded them on a chop saw or used an angle grinder with a zip wheel.
Old 12-09-2023, 04:47 AM
Exactly. Those look to be just about perfect joints. The mistake a lot of people make is trying to get the cope to overlap half of the mating pipe. As your pictures show, the reality is that you need only about one third (or even a tiny bit less) overlap to make a very weldable joint.
If you have a hydraulic press flattening the pipe is probably faster and, for a lot of applications, more than strong enough, but a nicely coped joint is stronger yet and looks a lot more professional...
Old 12-09-2023, 11:53 AM
I don't have a chopsaw, but I guess for this use it makes sense. The neighbor has one, but I'm the bandsaw guy, and we "argue" the merit of either choice being superior. I prefer the bandsaw for less noise, less mess in the air, gang cuts, and being able to start it and walk away.
I think I will do the pipe wrap and a zip disc on the grinder. After the 1st few I can probably just eyeball them. If not I will pickup a chopsaw and cope them in that way.
The same neighbor has a 20ton press, but I'm thinking that would be a lot of pumping.
Thanks for the suggestions.
