Old 11-22-2023, 06:54 PM
Scratch Scratch is offline
Default I need fabrication ideas
One of the products I make with my CNC plasma cutting table are coathooks. I cut out a name from 1/8" HR steel with a 1" bar connected at the bottom, then I cut out 2" circles from the same steel. I weld the circles on some 2" long pieces of 3/8" round bar, then weld them on below the name. Drill some holes and bam... coat hook.
I'm looking for a better way to weld the "hooks" onto the sign below the name. I already have a jig made to weld the 3/8" round bar onto the circles, but I feel there must be a better way to weld those assemblies onto the sign.
Right now, I have an 18" long magnet bar from HF. I stick the "hooks" onto the bar, then use some wood as a spacer to get to about 2", then weld them on from there. It works, but it feels like there must be a better way.
If you have any ideas, please let me know.
ID:	169464   Click image for larger version
Old 11-22-2023, 08:24 PM
Norm W's Avatar
Norm W Norm W is offline
Drill 3/8" holes where you want the coat hooks and weld from the back side. Makes a much cleaner looking sign with less clean-up.
Old 11-22-2023, 09:02 PM
+ 1!!!!!!!!!!!
Old 11-22-2023, 11:04 PM
I used to drill holes and weld them in from the back. It was much cleaner looking, but it was more work with drilling and grinding, and nobody really cared about seeing the welds so I decided it was easier just to weld them on.
Old 11-22-2023, 11:59 PM
Do I have a life?
THIS^^^^
I think you answered your own question...
What if you just burned the holes with the plasma cutter?
HF 80 lunchbox w/tig
Old 11-23-2023, 07:51 AM
I would think it would ultimately look much cleaner if you plasma a 5/16” hole to plug weld. You could do this to the circle piece too. Hit it with a sanding pad in the grinder, to flush it, and everything is flat.
Much easier than trying to maneuver the gun around the rod, trying to keep bead uniform.
Since these are “custom” signs, I would shoot for the highest and cleanest appearance. If it takes a bit more time, then so be it. Unless you are mass producing them and need to cut off seconds to make a profit and sell at China pricing.
Old 11-23-2023, 09:37 AM
I’m not really looking for a better idea on how to weld the pieces together, but how to align and hold the pieces together vertical, straight and plumb while they’re being welded. Some sort of jig or something…
Old 11-23-2023, 09:42 AM
camdigger's Avatar
Roving Reporter
+1. Clean and no drilling.
Old 11-23-2023, 11:34 AM
An arm with a v to hold it, and a toggle clamp or screw clamp to press it down onto a base. Since it’s a common thing for you to do, use a steel plate for the base, weld the arm with a vee to that. Then have a section of arm beefy/big enough to mount your clamp of choice.
Or if you have a press you could do it there, press together, tack, then pull it out and finish the weld.
Old 11-23-2023, 03:26 PM
Something like this maybe
