  #31
Old 07-25-2014, 08:28 AM
Originally Posted by Bountyhunter View Post
Attachment 117283 Finally found the one I want. this is my son on a winning run in Darwell 2 yrs ago. I may just put in the stock solenoids in for the next pull and then persue better solenoids when the pressure is off. I am calling my supplier in the morning as Cole Hersee has some with silver contacts but only 200 amps but 700 intermittent so will see what the price is.
Silver will provide better conductivity, but has a lower melting point then copper and will fuse nicely at those amperages.
I think that Cat 1500 amp one from Texasindustrial would do it
  #32
Old 01-10-2024, 01:43 PM
Tsimshianman Tsimshianman is offline
Default Gord Whalley
Oh Gawd! Not another one of those evil tractor pullers. We used to be in the game once upon a time--knew quite a few of the Alberta pullers--Gord Whalley, Terry Graham come to mind; there were lots of others but it was a long time ago and the mind is getting feeble. What do you call your rig?
I saw Gord Whalley mentioned here.
His son just sent me a picture of him at the first tractor pull at BC Place which he won.
  #33
Old 01-16-2024, 02:51 PM
gimpyrobb's Avatar
Have you looked into gear reduction starters?
I went from a direct drive to a gear reduction starter on my military truck and the difference was night and day.
Also for something like a starter motor, you can feed a 12v model 24v and it should be fine as long as all the other systems are in operable shape. I would try running the starters in parallel with 24v.
