Old 07-19-2014, 11:26 PM
Just put in a big ass knife switch and be done with the solenoids
Old 07-19-2014, 11:31 PM
What changed, likely the batteries are aging and not putting out the voltage they used to under load. Lower voltage, higher amperage. You need a solenoid that can handle the amperage. I wonder if changing to a 24v starting system would be easier?
Just out of curiosity, can you put a dc amp clamp on the cables and see what kind of amps you are pulling?
Old 07-19-2014, 11:37 PM
Originally Posted by Bountyhunter View Post
You folks are asking what changed and the only thing that I can come up with is that I went from starter batteries on a cart to on board batteries. The starter batteries run only the starters. There is a third battery that runs the fuel pumps, ign and the switch that engages the solenoids. When the batteries were on a cart, I don't ever remember the solenoids sticking.
There you have it, a separate battery to run solenoids that will not be dragged down by cranking.
You will have to go back to that third battery, and can still have your on boards.
Old 07-19-2014, 11:51 PM
Bountyhunter Bountyhunter is offline
The solenoids are energized by the third battery now. I have tried running the solenoids of of one of the starter batteries and currently have them running off the third battery and it didn't seem to make any difference. Granted I have never tested the third battery and 3 fuel pumps and 3 ign systems might be taking it down too much. I can test that with out too much problem with it sitting the way it is.
Harold
Old 07-19-2014, 11:54 PM
Tech guys really frown on that. Has crossed my mind tho. For some silly reason they want this thing to only start in neutral
Old 07-20-2014, 05:46 PM
kd4gij kd4gij is offline
Why not go to a pneumatic starter system like tractor trailers use now.
Old 07-20-2014, 06:41 PM
SmokinDodge's Avatar
I haven't seen an air starter on anything on road with a build date after 1972.
Sent from my ipotato
Old 07-20-2014, 07:16 PM
monckywrench's Avatar
trust but verify
http://www.powrquik.com/
Pneumatic and hydraulic. Interesting stuff...
http://www.tandbrepairs.com/
Old 07-21-2014, 06:38 PM
DeepSeaDynamo's Avatar
DeepSeaDynamo DeepSeaDynamo is offline
That may be, but like 90% of the engines that we used offshore were air start, and they sure do work well as long as you have enough air.
Old 07-21-2014, 08:09 PM
rustythe4x4's Avatar
You guys would know Lyle and his son ot of Saskatoon.
They ran a pulling tractor for years. I never got to see it in person...
Living the country life
Mathew 10:36
-Ironman quoting the Bible
