Neo-con: another name for moderate democrat |
A little info:
http://www.paiste.com/e/about_alloys.php?menuid=314 http://www.statemaster.com/encyclopedia/Cymbal-alloys
USMCPOP |
Buy an extra cracked one and use strips of it as filler wire.
Walker Chief slag chipper and floor sweeper, Ironwood Artistic |
That is a great idea!!
I think that it might be a good idea to consider preheating them before the repair attempt and then a controlled slow cooling off period. Might help with keeping the proper temper needed for the sound quality.
Running away is the coward's way out of war. Appeasement is the coward's way into one. Biden & Harris is our enemies favorite candidates In time the right project will find the scrap pile, no need for the scrap pile to go out looking for a project. http://www.swiftvets.com/phpBB2/viewtopic.php?t=24981 http://tosettherecordstraight.com/index.php |
You might also consider silver solder instead of welding.
What brand are they?
I think the weld will mess with the tone.
Tim Self appointed director of junk, and old vehicles. |
the high end stuff is all lathe spun as far as I know.... and the work hardening during the spinning process is a lot of what gives them their unique tone and sizzle.... that work hardening is what allows them to crack when x-amount of playing hardens them past the threshold.....have tried to repair some over the years ... they repair fine but the HAZ changes the entire audio signature of the beast... makes em flat and takes the sparkle out and turns it into a THUNK...... might be able to hammer planish or bead blast to restore the temper and tone... but is it worth all the effort??
hope this helps Heiti |
Sero Sed Serio Acta non verba |
Well then.... forged and then spun...
From past experience the only way to salvage an 18" cymbal, that is cracked 2" from the edge, is to make it a 14" cymbal. The crack will follow all the way around the circumference and welding, brazing, etc. will take out the temper. If the crack is small drilling "Stop holes" will sometimes work for a while. If the cymbal is played hard it won't last long. Drilling holes along the crack and riveting the holes, with small brass rivets, will help the longevity but it does deaden the sound.
Norm
Make over, make do, or do without Why do I have to press one for English when you're just gonna transfer me to someone I can't understand anyway? Grant me the strength to accept the things I cannot change, the courage to change the things I can & the friends to post my bail when I finally snap! |
