Old 03-04-2021, 09:00 AM
Just curious, would it be critical if the dimensions were off a 32nd or so?
Not at all, I am more concerned if the engineered products relate to size the way dimensional lumber does. As you may know dimensional lumber measures 1/2”-3/4” less than the stated size.
Old 03-04-2021, 09:13 AM
Page 3 of the Western BCI and VersaLam Specifier download shows actual dimensions. That's where I would start. I look at it as the same as going to a Ryerson steel catalog and finding out a W14x283 has a height of 16.74" and a width of 16.11", not the nominal 14" used in the description.
Yes, the Eastern Specifier that I looked at shows the same but I did not see the word “actual”.
Your reference to a W14x283 had me thinking you made a error in typing as a 283 lb. 14” beam seems ridiculously huge. Imagine my surprise when I discovered a W14x730!!! I have spent a fair amount of time looking at listing specs in my Ryerson, I don’t recall anything like this.
Old 03-04-2021, 09:31 AM
I suspect the Op is building some welded steel sockets to hold the wood I-joist's
Yes, something like that. I am still not committed to using wood, I may use steel in some form.
Old 03-04-2021, 08:12 PM
My Ryerson catalog does not say actual, but it does have a section in the appendix for allowable tolerances. If a manufacturer shows a dimension in a catalog, I will take that as gospel WRT tolerances.
Hours and hours of welding 4" baseplates to W14x283 columns. Not very often would you find them used horizontally as a beam, does not make sense material wise, but as a column they are specified quite often. Buckling is not your freind.
Old 03-06-2021, 08:34 PM
Yes, I think the same about dimensions in a catalog but I thought to check with others to boost my confidence. I guess no one here has used LVL.
Below is a picture of pages from my Ryerson stock book. It shows the largest W14 at 99 lbs. The heaviest is a W10 at 112 lbs. The larger ones I found listed on an internet sight. I suppose the others are not available to common folks.
