Old 04-17-2009, 03:37 PM
Originally Posted by Fla Jim View Post
I just got the info from this site:
http://grizzly.com/products/9-x-32-G...th-Stand/G0484
But you're right when I went to the catalog page, it listed 120
http://www.grizzly.com/catalog/2009/Main/536
Jim,
The whole speed selection is different, from the first post to the second post, makes you wonder which set of information is correct.
Jack
Old 04-17-2009, 04:32 PM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
it is wired for 220 but will work on 110. I have both, what is the best and why?
Old 04-17-2009, 04:50 PM
Fla Jim's Avatar
Fla Jim Fla Jim is offline
Harbor Freight Backslider
220, half the amps. But saying that, when I had my mill drill, I left it wired
110.
I think it drew about 20 amps at 110. I tripped the breaker a couple times, doing heavy milling. I put the table feed and two lights that I had on it on a separate circuit.
Jim the Shop Rat
From Jim’s Magic Garage®
Old 04-17-2009, 06:20 PM
As Jim said, there is no real operational difference, If its 20 amps on 110, then the amperage would be 10 amps on both hot legs on 220, so the wattage would be the same. Depending on the motor design, some of them will get to full rpm a little faster on 220 vs 110. I was told by a Marathon motor service tech, if its a constant run motor, there is no difference, if the motor is to be shut on and off alot, then 220 is better as its easier on the motor windings, whether thats true, I'm not sure. As the amperage is lower each leg on 220, you can run smaller wire, to a point, but you will also need a 220 volt double circuit breaker.
Jack
Old 04-17-2009, 09:26 PM
precisionworks's Avatar
if the motor is to be shut on and off a lot, then 220 is better as its easier on the motor windings, whether that's true, I'm not sure.
120v is marginal above 1 hp, and the voltage sag means the motor is often trying to start with under 100v. 240 has minimal sag, the lights in your shop don't dim, the breaker doesn't trip, and the motor immediately comes up to full speed. 240v is a clear winner, and you'll need a double pole breaker that fits your panel.
PM's are disabled
Old 04-17-2009, 09:34 PM
OLD MAN's Avatar
Nobody was faster
It will be about 10' from a 200A service entrance and I have blank slots. I will just run a piece of condiut and put in a dedicated 220v plug.
Old 04-18-2009, 12:01 AM
Are we there yet?
I'm wanting an update already.
Are you really gonna leave it that color?
We need pictures.
What about tooling?
What does Kat think about it?
Did you run 3 or 4 wire 220?
How you gonna sneak this one past Mrs. Old Man?
I bet you better run 4 wire for when you add the DRO.
Its gonna take one hell of an anniversary present next year, you know.
Hey - this thread is named wrong now.
Old 04-18-2009, 12:03 AM
OM,
you need too find someone that has one of these mills and ask them if it's any good.
Maybe its ok, but I don't like the swivel and size of the dovetail mount.
Old 04-18-2009, 01:27 AM
OLD MAN's Avatar
Nobody was faster
GWIZ THIS IS THE ONE i BOUGHT
http://www.use-enco.com/CGI/INSRIT?PMAKA=307-2792
Old 04-18-2009, 01:33 AM
OLD MAN's Avatar
Nobody was faster
Are we there yet?
We need pictures.
What about tooling?
no
me too
yes
me too
making an order now
She don't know
will run 4 wire.
52"tv to block view.
yep 4
already covered.
yep.
Tags
mill/drill
